| dransy |
 dransy World Chat Champion
| stinkwheel |
 Posted: 18:27 - 28 Aug 2011 Post subject: |
The metal tends to split if you just bolt them on, even with penny washers on the inside.
A bit of thin plywood on the inside of the box, with a couple of bolts and penny washers going through it to attach them to whatever rail you cobble together is good.
It's also good to have a wee bit of support from underneath if possible, even if it's only a bit of L-section for the edge nearest the bike ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| dransy |
| Billing |
 Billing World Chat Champion
| stinkwheel |
 Posted: 01:01 - 29 Aug 2011 Post subject: |
It's pretty thin, fairly springy steel they're made of. I'd worry about it splitting next to the weld (or there's a pretty good chance of blowing a hole in it depending on how good you are with a welder).
The plywood insert thing is tried and tested. You cut a piece of ply the same size as the side of the box, put it inside and bolt it on through that. Two M6 bolts with a penny washer is fine.
Another top tip for ammo boxes is to drill a small hole between two of the hinge sections and put a pop-rivett through it with the flat side on the inside of the box and the 'popped' part to the outside. This prevents the lid sliding sideways and coming off the hinge pins every time you open it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| reesk92 |
 reesk92 Derestricted Danger
 Posted: 03:57 - 29 Aug 2011 Post subject: |
a quick search at google for gs500 ammo boxes turned this up
https://farm5.static.flickr.com/4124/5188095312_553f6f51b7.jpg
mybe something similar would work for you maybe not exactly but why not make a support frame up out of thin metal plates then mount the boxes inside
also what exact model do you have cause the bike i found it dosent suit the look idk maybe you have a older one or a more millitary looking one |
| stinkwheel |
| dransy |
| dgo1212 |
 dgo1212 Brolly Dolly
 Posted: 20:18 - 29 Aug 2011 Post subject: |
| Martay |
 Martay World Chat Champion
| deleted111 |
 deleted111 World Chat Champion
 Posted: 20:43 - 29 Aug 2011 Post subject: |
^^ You've got me thinking about doing that to my CG now.
I like it, have a Karma cookie.  |
| stinkwheel |
| dannyjohnson |
 dannyjohnson Banned
| chillyman0 |
 chillyman0 Nearly there...
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
