How I made my bike happy...
Milo
PostPosted: 18:33 - 02 Mar 2004    Post subject: How I made my bike happy... Reply with quote
Nope, it didn't invole promising it I'd never take a soldering iron to it again!
I'd only been commuting on my bike for a few months now and all the short journeys were taking their toll on the engine!
On friday I was going to Southampton so the long journey would've worked a treat on it's own but I filled the tank with Optimax and a bit of Redex and now it responds much faster (got normal tesco fuel in it now) and starts much easier.
I think the long ride did the best for it by getting rid of all the shite (carbon?) that's been sat in there but I'm sure the Redex has helped too. Doubt the Optimax did any good after it had ran out but what the hell - I'd not used it on this bike before so why not eh?
Anyway - I'll keep you posted if the Redex seems to make a difference long-term as I'm currently using every time I fill up.
Adam Smile
Shaft drives rule. Razz
ZaphodBeeble
PostPosted: 18:41 - 02 Mar 2004    Post subject: Reply with quote
I'm not really a fan of Redex. I'd rather strip down an engine and clean it myself. I don't like adding any chemicals to the already chemical'd up petrol. I suppose it's ok if you don't want to or are not able to strip down your engine as Redex is the best bet for cleaning, but personally I wouldn't use it.
But, if it worked for you then it's cool... Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
ilovens125f's
PostPosted: 18:46 - 02 Mar 2004    Post subject: Reply with quote
I have used redex on my NS125F it seemed to work. .i.e Reduce carbon and for some reason it seemed to stop smoking as much(Carbon Reduced).
Then I reborded it so I couldent tell much. For the obvious reason.
Anyway Good luck
Kev Thumbs Up
Kev the Ns125F lover!!
!!!Dont ignore me!!!
M1ke
Ped Boi
PostPosted: 18:55 - 02 Mar 2004    Post subject: Reply with quote
The other day when I went into wales I accidently pulled up to an optimax fuel pump instead of the normal unleaded... I didn't want to look like a plonker so decided to fill the tank (from empty) with this optimax stuff.
The tank was 100% empty as I had ran out of fuel just up the road... (i blame the fuel leak)
Anyway, instead of getting my normal 150km to a tank, I got 195km! So it must burn slower or something as it increased my MPG.
Milo
PostPosted: 20:20 - 02 Mar 2004    Post subject: Reply with quote
It's slightly more powerful do you can cruise at the same revs but putting less fuel into the engine.
On the way back from Southampton I used 1/3 of a tank in stead of the normal half. Before I've rocketed there and back and had to fill up on the way back! Speed really does make a big difference to the tank range so i've started cruising at lower speed (75-90) if it means the difference between having to stop to fill up or having to bother unwrapping the warm clothing off of myself to be able to fill up.
Also i've become very lazy and only fill up at Tesco where I don't even have to get off of my bike to pay, it saves so much hassle!
Adam
Flip
PostPosted: 20:49 - 02 Mar 2004    Post subject: Reply with quote
Just started using redex on my NSR about a week ago and it seems to run that little bit smoother! Even started first time when it was -2 the other morning!! Very Happy
Not used optimax though.
Milo
PostPosted: 20:57 - 02 Mar 2004    Post subject: Reply with quote
The Optimax was kind of a "why not" at the time cos people were queueing at Tesco so i went to a Shell. I'm sure it helped the economy of the bike (I'm sure I could get 250 out of a tank with the stuff) but it's not worth the extra money.
My bike generally starts fine in all temperatures but sometimes just doesn't like starting when cold for a couple of attempts even in those warmer totally dry days. It does start easier and seems to initially be smoother rather than having only a couple of cylinders fire up at first.
Flip
PostPosted: 21:08 - 02 Mar 2004    Post subject: Reply with quote
Might give optimax a miss then, but anything that makes a bike start first time when its freezing is bloody good in my book Thumbs Up
R1stu
Shrek!
PostPosted: 21:09 - 02 Mar 2004    Post subject: Reply with quote
I found the Optimax made the R6 run better too. Milo, what were you doing down my way?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Milo
PostPosted: 21:25 - 02 Mar 2004    Post subject: Reply with quote
Southampton? I was seeing my girlfriend at uni at the institute's Kimber halls.
Went to Kaos on Friday night which was cool but I was too knackered to stay for very long!
Oh, and Flip - my bike being better is probably more down to the fact it's had a good hot run though I'll keep using the Redex anyway.
Mr C
PostPosted: 22:45 - 02 Mar 2004    Post subject: Reply with quote
my bike was running on Optimax when it made 187 bhp on the dyno
187.3bhp = 201mph
AcIdBuRnZ
PostPosted: 00:04 - 03 Mar 2004    Post subject: Reply with quote
That's it, keep rubbing it in!!!
I'd be happy with the 87HP Rolling Eyes
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
Mr C
PostPosted: 08:58 - 03 Mar 2004    Post subject: Reply with quote
sorry
I can't help it Cool
187.3bhp = 201mph
stevo as b4
PostPosted: 23:30 - 03 Mar 2004    Post subject: Reply with quote
Optimax or other higher than normal 95RON fuel can improve power and performance slightly, but only if you can advance the ignition to suit. I wouldnt bother on a 2 stroke, unless your running a higher CR than std, in which case you will probably need an octance booster anyway. On electronically managed 4 strokes that are equipt with a knock sensor then sometimes they can take advantage of this type of fuel and improve power and throttle response slightly. On my car it makes no difference as i dont have a knock sensor, so the ECU cant change the timing. I thinks thats where superchips come into it!
Mr C
PostPosted: 21:41 - 04 Mar 2004    Post subject: Reply with quote
I'm running 3 degrees of advance across the upper rev range and throttle position so I can use the Optimax OK and I think it does make a difference
the bike was "only" pulling 182 until the advace was dialled in
I will try adding some octane booster as well for racing and see if it has an effect Wink
187.3bhp = 201mph
The last post was made 21 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.05 - MySQL Queries: 13 - Page Size: 85.2 Kb
