Sanya 125
Trialsfan
PostPosted: 15:24 - 17 Sep 2011    Post subject: Sanya 125 Reply with quote
Hi.....my son has a Sanya 125 on an 09 plate which he bought a little while ago and I want to do an oil change for him but not sure what grade of oil it would need or quantity?
Any help would be appreciated.
regards......Trialsfan. Thumbs Up
cb1rocket
PostPosted: 15:40 - 17 Sep 2011    Post subject: Reply with quote
er...in the manual?
If not its usually 10w - 40 grade and the quantity of oil is usually stamped on the side of the engine near the filler cap
0ddball
PostPosted: 16:36 - 17 Sep 2011    Post subject: Reply with quote
Does it not have a sight glass? The Sanya i just flogged did. Don't forget the clean the mesh filter which requires removing the big bolt just in front of the gear change.
ZXR750L
Glenben92
PostPosted: 18:00 - 17 Sep 2011    Post subject: Reply with quote
If I recall correctly it's just a litre. 156FMI??? cg copy engine. The same lump that's in my HN125.
10-40 synth bike oil, I'd recommend
Just be careful as you fill up and keep a hawk eye on the sight glass / dipstick. Regular changes are a must, especially with such a primative motor.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Frost
PostPosted: 20:10 - 17 Sep 2011    Post subject: Reply with quote
As a general rule 10w40 is what you want, unless it's either really old or has few very large cylinders in which case something thicker is needed.
PostPosted: 21:50 - 17 Sep 2011    Post subject: Reply with quote
I concur. Also, get the mesh oil filter out and clean it. It's under a large nut on the side of the engine - nearside, at the bottom. 23mm, or thereabouts.
Trialsfan
PostPosted: 08:36 - 18 Sep 2011    Post subject: Sanya 125 Reply with quote
Many thanks for all your replies,great help.As for the first reply we did not get a manual with it,hence the post!
Once again many thanks....... Thumbs Up
Trialsfan.
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.28 - MySQL Queries: 14 - Page Size: 50.78 Kb
