Cb 125 TDE superdream
nightshaddow
PostPosted: 17:42 - 01 Dec 2011    Post subject: Cb 125 TDE superdream Reply with quote
To start off the bike itself is a 1987 125 superdream it has a few issues but mostly in good nick,
i aquired it as i was sick of the POR chinese bikes problems, this being the third CB twin i have had i am comfortable and comfident i can iron out the little chinks of a 25 odd year old bike and though i doubt it will be the standard off SnowTigeress and Teflon-Mike's pup and corpral respectivly i hope to get it up there over time and other than 1 or 2 minor alterations i plan to keep it compleatly standard,
Teflon-Mike wrote:
nightshaddow wrote:
this is the new beast in question
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/380003_10150443821828846_741698845_8703718_708279519_n.jpg
couple of lil niggles other than the gearbox
have to get rid of a real bad flatspot at about 7k rpm
all in all 350 with 12 months test on it a good deal and it gets the ole chineese crap gone
I've seen tidier.. but I also paid as much for 'The Heap', which has proved little more than dead-weight value! Crying or Very sad
Shiney pipes. You put them on?
Have you done the usual suspects? Oil Strainer, tensioned the cam-chain, set the tappets; synced the choke linkage, cleaned the carbs, and balenced the idle & slides?
If it goes wooly around 6-7K, on load, you ought to be well on the main jet, and usual suspect is the carb inlet rubbers are dragging air...
Actually an carb issue is to suspect carb rubbers! Everyone tears them trying to pull the carbs out without removing the air-box.
i think this is a compliment lol so a quick breakdown of what i have done and what i am going to do (hopefully)
I fixed the major issues which where the indicators that where broken so fit a set of L.E.D. ones i had i just need to make up an idiot light for it. the way the loom is set up if i have the bulb in for the idiot light all four indicators flash regardless of direction as it has one single idiot light for both directions.
She was also running on one cylinder (the reason i got her so cheap) a new set of ht leads ht caps and plugs paid par to that.
main things i have to address are the gearbox issue in fourth and the seat cover has a nasty rip and is covered in gaffa tape,
main thing i want to change is the gear ratios via the chain and sprockets, i travel on a duel carridgeway to work and she sits at 65 @10500 rpm
other than that the only real non standard thing i want to change is the handle bars they are too narrow for me i am used to and prefer wider bars
and then a general cosmetic tidy up to get it in a nice condition
sugestions and comments always accepted and critisizem also expected Very Happy more pics will come tomorrow (in the day light)
next to happen will be a full service to check everything, mainly the oil because of the gearbox issue and as soon as my new balencers arrive the carbs will be synced up too
nightshaddow
PostPosted: 16:06 - 04 Dec 2011    Post subject: Reply with quote
so here she is a couple of photos to see what state she is in
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc7/383309_10150453040683846_741698845_8728822_1806132594_n.jpg
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/383934_10150453040493846_741698845_8728817_1756454363_n.jpg
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/382720_10150453040563846_741698845_8728819_1483841561_n.jpg
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/387642_10150453040623846_741698845_8728820_2101681906_n.jpg
As you can see cosmetically it is not in bad condition but needs some attantion, main things will be polishing and the fuel tank and also a seat cover
mechanicaly she it not to bad either but due to a small problem with the gear box (whining and knocking in 4th) she will have a compleate rebuild when i have all the parts together.
electrically she is good apart from some minor wiring in the headlight which will be easily fixed,
first will be to get her running right and looking as the should before i make minor and subtle alterations to suit my wants/needs
nightshaddow
PostPosted: 16:24 - 11 Dec 2011    Post subject: Reply with quote
Yesterday my posty from royal fail brought me a lovely new tool to help in my quest to bring this bike to a bit more niceness Smile
https://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/378453_10150468761743846_741698845_8779371_110198772_n.jpg
well of course i had to get in there straight away and have a play and although it was slightly out after a couple of slight twists on the ole screwdriver she was ballenced once again
https://www.youtube.com/watch?v=nXmkekI1BGk&feature=youtu.be
UnspeedySam
PostPosted: 18:58 - 11 Dec 2011    Post subject: Reply with quote
Looks nice. I need to get myself one of those for the sake of both the Bros and the ZZR, both of which idle pretty badly.
I see you've also got a Draper impact driver. I got one a few months ago and the number of seized cheese-screws it's saved me from on the RXS is nuts.
nightshaddow
PostPosted: 18:24 - 16 Dec 2011    Post subject: Reply with quote
one of the problems with this bike when i got it was the indicators where snapped, this was not an issue so i fitted a set of led idicators as well as a new relay for the led's.
once i fitted them the indicators no matter which direction i operated activated all 4 indicators, knowing why this happened i pulled the "idiot" light and the system worked corectly,
following the advise and information by teflon mike
Teflon-Mike wrote:
Yes... Super-dream has rather clever indicator tell-tale wiring arramgement, that doesn't work with LED bulbs as we found on the Pup. (see Pup-Project Thread)
You need two diodes.
Diodes are one way valves for electricity. LED's are 'Light Emmitting Diodes'. So electric will only flow through them one way.
Two wires put on to batt poss one to ground, they will light up. Swap wires they wont.
Do that with conventional tungsten bulb, it will light up whichever way electric flows.
Super-dream utilises this feature of the tungsten bulb for the tell-tale.
Indicator volts come from the battery, via the ignition switch; back to the flasher unit, then back to the indicator switch.
Here the indy switch point the volts either to no where, in centre possition (off) or to the left indies or right indies.
Volts go through bulb, and return to the battery via the chassis earth.
(Tip; make up an earth strap from the indy to the chassis, at the rear, there is a rubber isolation block in the bracket, and a seperate link wire around it that often snaps, gets lost of corrodes up, giving poor earths; Fronts bring to common earth in the headlamp for same reason)
So, Tell-Tale.
Tungsten bulb between the clocks, and two wires.
One wire is linked in the head-lamp to the +ve feed to the Right indicator (I think orange wire)
One wire is linked in headlamp to the +ve feed to the Left indicator (I think pale blue wire)
When volts on Left indies, volts can flow through the tell-tale lighting it up, and earthing through the Right hand indicator bulbs.
Voltage reduction accross the resistance of the tell-tale means that there isn't enough volts to actually make the two right hand indies light up, SO you get left indies and tell-tale.
Wen volts on Right hand indies, volts flow the OTHER way through the tell tale, earthing through the left hand bulbs...
Clever, isn't it?
BUT, if you have fitted LED indicators...
Volts on the Right hand circvuit are directed through the tell-tale and put on left hand circuit, and can be enough to light up low amp LED's...
So you can end up with all four blinkers working on either direction switch. Or none at all, depending on the LED wiring and or balast resistances.
Solution is, two diodes.
You make a Y-Piece of wire with a Diode in each arm, and a male bullet on each end, to plug into the indy circuits in the headlamp, wherethe tell-tale would.
You then put female bullet on the common branch and plug in one or other of the Tell-Tale leads to it, and then a short link wire, with a ring connector one end and a female bullet the other, to connect to the other tell-tale lead, and attach to the headlamp mountng bolt's 'common earth' point.
Now volts from indies on left go through diode, to tell-tale and direct to earth. Volts from indies on right go through other diode, through tell-tale, and direct to earth, but volts from left cant back-flow through the other diode to the right indies, nor vica versa.
How have you got the flash-rate sorted BTW? Have you used balast resistors or an electronic flasher?
I preffer the electronic flasher; chyrstal times the flash delay no matter what the load on the circuit, tungsten or LED, and if using LED's you dont have the current draw of big ballast resistors.
i built this
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/381313_10150480459448846_741698845_8814245_990003984_n.jpg
all tested on a 9v square battery the light seems to be working corectly with the 2 diodes in place i just need to fit into the corect place, this will however need to wait till tomorrow or sunday as it is now dark outside Evil or Very Mad
basicaly befor and after how this thing is on the bike and the new one
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/378610_10150480493288846_741698845_8814326_592223401_n.jpg
nightshaddow
PostPosted: 14:03 - 18 Dec 2011    Post subject: Reply with quote
well today i finally got to fitting the idiot light i made, as you can see with the bulb in the original loom all four indicators flash withought the idiot light lighting up which of course is no good.
https://www.youtube.com/watch?v=2p93T1knykc&feature=youtu.be
so of course into the wireing at the frount and wired in the new idiot light, for the keen eyes among you you can see i have left the whole system so it can be easily removed at any time also
https://www.youtube.com/watch?v=uSmQNGfIEl8&feature=youtu.be
so with everything figured out eg where my earths will be and also where to route the new wireing i rebuilt the frount end and here she is
https://www.youtube.com/watch?v=hE6AV6adeOE&feature=youtu.be
so now all the electrical problems are sorted i will make a list of what to do with this bike and tackle everything in order,
gotta say big thanks to teflon mike for this one as i knew why it was happening but not sure how to fix Thumbs Up
nightshaddow
PostPosted: 19:03 - 07 Jan 2012    Post subject: Reply with quote
so i have now made a list of what i would like to do to the bike to bring it up to scratch and it will probably take a while to do but this is the list
FROUNT END
polish frount wheel
polish frount forks
new headlight
new handle bars
paint frount mudguard
paint triple trees
service brakes
paint/upgrade/replace caliper
paint headlight mounting
paint switchgear
replace / paint mirrors
tidy up clocks
MID SECTION
pull out dent in fuel tank
repaint engine casings
repaint fuel tank
repaint side pannels
full engine rebuild
new gearbox
check and replace bairings
pistons/ rings
valves and seals
etc
rear section
polish up rear wheel
powdercoat swing arm
tidy/paint chain guard
recover seat
paint rear plastic
polish rear trim
replace rear lights
seeing as the bike is in reasonable nick already i will work through frount to back etc this should be made easyer as i have a compleate bike in spares though there are cirtain bits that are beyond repair on both machines
nightshaddow
PostPosted: 15:08 - 08 Jan 2012    Post subject: Reply with quote
today i decided to do an oil change on the bike to see if there was much in the way of metal floating in the oil from the damaged gearbox, (hopefully post a video soon of the problem)
the oil looked healthy but decided to look at the oil strainer while i was at it, though i didnt get a pic at the time the inside of the clutch cover was thick in a white creamy substance that was not mixed in with the oil..... air cooled bike thoughts on this would be good!
this was when i found my first unexpecteted minor suprise
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/403818_10150527628263846_741698845_9016333_2081137524_n.jpg
as you may see with good eyes there is a crack in the metal around the bolt hole in the casing
so then to the oil strainer
all looked in prety good nick though there where signs of metal shavings which only reafirms once all the parts have been gatherd a full engine rebuild will be nessesary
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/381238_10150527628728846_741698845_9016336_260795827_n.jpg
so after around 5 mins of cleaning getting it all clean this is how it looked
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/397285_10150527629283846_741698845_9016338_1960560971_n.jpg
so i rebuilt her up dropped in some oil and fired it up and she sounds sweet again, the engine is now only a few miles off 30k i hope i can get it to do 30k more
nightshaddow
PostPosted: 11:50 - 24 Jan 2012    Post subject: Reply with quote
well slow progress atm but i am still trying to source parts for the gearbox, and being on a tight budget it not easy going
saying that mr posty and royal fail delivered this this morning
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/396973_10150566017158846_741698845_9133701_150019787_n.jpg
i have already decided if there is any exesive loss in compresion new barrels and pistons will be ordered and i will rework the head rether than chase problems,
my moto do it once, do it right Smile
SnowTigeress
PostPosted: 19:29 - 24 Jan 2012    Post subject: Reply with quote
new headlight
tidy up clocks
seeing as the bike is in reasonable nick already i will work through front to back etc this should be made easier as i have a compleate bike in spares though there are certain bits that are beyond repair on both machines
Back to blacks good for the chain guard and rear mudguard, air boxes and all the black plastics
what you thinking of doing with the clocks?
the Back to black also works to tidy up the case
And what headlamp you thinking of, a replacement CB125 or something like what ive put on the Pup which was a gs500 headlamp?
It costs a lot to overhaul the front brake system think it was around £150
£35.25 for pistons
£25.85 for master cylinder kit
£15.86 for calliper seal kit
£3.46 for bleed nipple
£3.23 for bleed nipple cap
£10.57 for Brake pad guide pin
£9.98 for front brake pads
some boots for the float pin but can`t find it on my price list
and if you want a better brake line a Goodridge brake hose for £21
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
SnowTigeress
PostPosted: 19:37 - 24 Jan 2012    Post subject: Reply with quote
oops double posted
nightshaddow
PostPosted: 10:54 - 25 Jan 2012    Post subject: Reply with quote
not 100% yet on that one, i can buy brand new CB ones at around £60 i think but i may look at the earlyer twin clocks
again not 100% here either been fooling around with a few diferent ideas, i can get an original brand new headlight for just under £30 but i been thinking of twin headlights and also possibly something like the mbx headlight cowl maybee even the belly pan too but not decided yet
https://bike-exchange.com/images/Honda%20MBX%20125.jpg
£35.25 for pistons
luckily my brake system is in good working order so to bring it back up to scrach it is mostly cosmetic and service though i have been playing with the idea of "upgrading" the caliper and disc but this will require some research as to what will fit though my brake line will be replaced with goodridge hoses or better.
at the moment i am concentraiting on getting the bits together for the engine, hopefully later today i will do a compresion test and post i video for all to see the results Smile
also it seems my single cylinder fireing has come back, only when it is cold so i have to check out the coils plugs and leads to see what has changed,
i going to have to look into what i need to do to fit my other engine as i believe it is a cd 125 points engine and my cb is cdi also i dont want to change anything perminantly as the engine once re conditioned will be going back in there,
if i post up the engine number could anyone tell me more about the engine Thumbs Up
SnowTigeress
PostPosted: 14:03 - 25 Jan 2012    Post subject: Reply with quote
I think Tef has the List of engine numbers still so should be able to help
mysterious_rider
PostPosted: 14:11 - 25 Jan 2012    Post subject: Reply with quote
old school bike! Pretty awesome mate you're doing well with it.
One question, how on earth does that carb balancer work? Easy to do? Considering doing my engine. Smile Thanks!
garth
PostPosted: 14:19 - 25 Jan 2012    Post subject: Reply with quote
£150 overhauling a front brake on a CB125 is utter madness.
Teflon-Mike
tl;dr
PostPosted: 15:12 - 25 Jan 2012    Post subject: Reply with quote
No, just expensive.
And that's to overhaul the complete system; master-cylinder; hose, and the caliper.
Most of the cost of the job is in the caliper, which is a twin piston floating item, & Just because it's fitted to a little bike, doesn't mean the piece parts are going to be any cheaper!
Hence £16 x 2 for new pistons, accounting for near half the cost of overhauling the caliper.
Certainly galling to spend THAT much money on overhauling the caliper to go onto a 125, but still half the cost of overhauling the twin calipers on my 750.....
Did it on Snowie's bike, as a learning excersise, and she wouldn't have learned how to over-haul a caliper fitting a marginally 'better' second hand one....
And ultimately, before you GO, make sure you can STOP!
Brakes is important! It's cheaper than a top end rebuild, and no-one would suggest that was 'daft'!
nightshaddow
PostPosted: 15:23 - 25 Jan 2012    Post subject: Reply with quote
i will do a detailed vid for you on the balencer but there are a few on the net already,
basicaly you conect it to the inlet manafould's and run the engine and it tells you how much of a vacume there is in each cylinder they should be even to be right if they read different then they need setting up basicaly
so anyway pics of the cd engine as the engine number will showhttps://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/396443_10150568849223846_741698845_9141138_1983097861_n.jpg
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/405315_10150568849008846_741698845_9141135_400379388_n.jpg
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/430081_10150568849093846_741698845_9141136_335648942_n.jpg
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/403758_10150568849153846_741698845_9141137_1349343565_n.jpg
any info on how to se this up in my bike would be greatly apreciated as my next post will show i think mine needs to come off road asap Thumbs Up
Welshd1k
PostPosted: 15:36 - 25 Jan 2012    Post subject: Reply with quote
exactly! buy a second hand one lmao could brobaly get a whole bike for that !
Teflon-Mike
tl;dr
PostPosted: 17:41 - 25 Jan 2012    Post subject: Reply with quote
People spend more money than that to get less benefit; like buying removable baffle exhaust pipes!
Hmm, good BRAKES or a nice exhaust noise? Tricky one that..... I cant quite make up my mind, which is better to get. Rolling Eyes
That looks like its a 12v motor. & Inside out mag-rotor suggests CDI ignition.
Make sure it turns over & has decent compression before you go any further.
Lump ought to slot straight into the frame, bolt for bolt, but personally I would:-
1: Pull the Rotor; ought to come off with I think an M14 bolt. If you dont have one, I'll stick one in the box of bits for you on Saturday. If it wont come off with that (& Chances are it wont!) Take lump to an engine reconditioners and get them to wip it off with a fancy hydraulic puller for you, for beer money.
Lurking in the back of that rotor is the Starter-Clutch. Simple mechanism, three rollers on ramps. Judging by the state of the rust on the rotor, the clutch will be in a horendouse state!
Clean up the rollers and the ramps, grease and reassemble, and you ought to avoid starting 'whine' the clutch not engaging, or worse, refusing to dissengage.
2: If the starter motor on your bike is 'good' wip that one off and fit it to this engine; remove an unknown quantity.
3; The difficult bit..... Sorting the ignition.
That engine has 360 Degree Crank, both pistons riding and falling together.
Your TD-E engine has 180 Crank, one piston up, one piston down.
Both engines run a 'lost spark' ignition, the coil sparking a plug umpety degrees fefore TDC on each revolution of the crank, triggered of a 'lump' on the Rotor, passing an inductor trigger.
Firing each rev, you get one spark when you want it, when the pistoin is rising on Compression stroke, and another, that is 'lost' firing when the piston is rising on the exhaust stroke, and makes no odds to anything.
The 360 Benley engine, with both pistons rising and falling together, can use a single ignition circuit, with a single 'Siamesed' coil, with two HT-Leads firing two spark plugs at teh same time... one pot will be on compression, one on exhaust...
The S-D engine with its 180 Crank, has to have two independent ignition circuits, one for each spark plug to give the 180 degree phase difference between firing intervals.
So your bike has two coils, two CDI units and two inductance triggers, places 180 degrees about the rotor inside the mag cover.
SO... fitting THAT engine, you need to take the inductor trigger signal from ONE of the two triggers, and feed it to BOTH CDi units, isolating the unused trigger.
It can be done replacing one coil with a siamese one, but the load on it can fry the CDi, so better to do as described.
You just have to do it in a way that is reversable, so check the wring diagram, I think that the inductor triggers come out in one 'branch' from the rotor cover, and go up to the main loom via a multi-way plug.
I would probably tap into the wiring there, on the spur from the mag-cover; isolating the two trigger feeds and bullet connectoring them so I could re-attach, when swapping back, and then use a Y piece to common the feed from whichever trigger gave the right timing, to the two CDi's.
Ignition on these bikes is self exited, and the ignition switch works on the CDi's, so it ought not need any more muggering around in the main loom; just the mag-cover spur.
nightshaddow
PostPosted: 18:13 - 25 Jan 2012    Post subject: Reply with quote
ok so the first compresion test is in and i need thoughts and ideas
https://www.youtube.com/watch?v=jZ1z-Kugy54&feature=youtu.be
Triumph1300
PostPosted: 18:46 - 25 Jan 2012    Post subject: Reply with quote
Rule 1 of compression testing - Open the throttle wide!
Rule 2 of compression testing - If values low, add a teaspoon of oil to the cylinder, and re-test. If it improves dramatically, it's the rings, if not, do the valve clearances.
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
nightshaddow
PostPosted: 18:48 - 25 Jan 2012    Post subject: Reply with quote
will give it a go straight after my food Thumbs Up
nightshaddow
PostPosted: 20:31 - 25 Jan 2012    Post subject: Reply with quote
for some reason or another my videos didnt save this time so no video of the second tests
first of all i did the valve clearances then proceded with a dry test
left 60psi right70 psi
no change on the left + 10 psi on the right
both sets of tappets where above 0.05 mm but now set right
then i did a wet test Neutral (put about 10ml 2 stroke oil in the cylinders)
left cylinder jumped to 90 psi right cylinder jumped to 110psi
a gain on the left of 50% a gain on the right of about 55%
i would definatly say time for a top end rebuild could be bad news but a full engine rebuild on its way anyway so no problem
MickC
PostPosted: 20:40 - 25 Jan 2012    Post subject: Reply with quote
Yep! That sums that up. If your thinking of a total rebuild you may as well do it then. Shop around and you may fine some NOS barrels for less than a re-bore. Head, change valve seals and re seat valves job done! Apart from cam chains and anything else that crops up.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Teflon-Mike
tl;dr
PostPosted: 21:16 - 25 Jan 2012    Post subject: Reply with quote
Riders of Yeoville:
Barrel & Piston Kit £75.00
https://thumbs3.ebaystatic.com/m/m0BLlBp_FegyP96U65p9IUQ/140.jpg
Camshaft & Bushes £37.00
https://thumbs1.ebaystatic.com/m/mByAJSxbd6sH-vdVuXSTAWw/140.jpg
Clutch Springs £4.29
https://thumbs3.ebaystatic.com/m/m0UIGHfAiVKhHyzZMbXJkpQ/140.jpg
Clutch Plates £10.21
https://thumbs2.ebaystatic.com/m/m3VuP4N8aDTiRmj4vIe9-wA/140.jpg
You'll also want one of these:
https://thumbs1.ebaystatic.com/m/mP9d0coARrcIx5LDz5xEVUA/80.jpg
Castle Nut Socket to get the clutch basket off with. £12.60
Then you can add £25 for a Cam-Chain.... NO point rebuilding the engine without a new one.....
And £25 for a gasket set, and another £12 for the Crank-Case oil seals....
All in, around £200's worth. IF the crank is good. Never had one reconditioned; from research I anticipate 'around' £150 to get one done, with new bearings.
The last post was made 14 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 172.45 Kb
