 blade023 Trackday Trickster
 Posted: 18:55 - 06 Dec 2011 Post subject: Starter motor not engaging sporadically |
So I went to get some oil for an oil change, got on the bike and it wouldn't start. I pressed the starter button and heard a click, which sounds like the relay, but no other sound. Got my trusty multi meter out and checked; 12.something volts from the battery. So I decided to bump start it, which was touch and go (or not ) as it's a carbed twin engine so I had to be careful keeping it running as it's been a little cold here lately.
I went round the block and came back onto the car port, and tested the starter (with the engine running) and it turned over fine. So I stopped the engine and tried the starter again; same thing. Putting the bike in gear and rocking it forwards seem to sort it, it started fine. I managed to get to the shop and back ok but got the same thing; to get the starter motor working I put the bike in gear and rocked it forwards, then it started ok.
So does anyone have any ideas about what might be causing this? It's the first time this has happened on this bike, but I had a similar thing with my last bike (125 with a copy of a cg engine.)
Before anyone says it, it's not the subframe. I've had it straightened since I got the bike. Cost me a couple of hundered but was definately worth it as the bike now feels a lot more ambitious and generally less aprehensive about life in general. ____________________ Current: VFR800 2008 13.7k and rising rapidly!
Sorn: 2003 FZS1000 30k(ish) looking to sell. |
 MickC Spanner Monkey
 Posted: 20:09 - 06 Dec 2011 Post subject: |
From what you say (rocking it in gear) it sounds like the starter motor isn't engaging/disengaging from the engine. Don't know what make or model you have, but try starting with the starter motor clutch assembly. It does seem odd that an oil change (assuming it's the right oil for the engine) would be the cause, were there any starting problems before?. ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
 Posted: 20:55 - 06 Dec 2011 Post subject: |
| Quote: | it sounds like the starter motor isn't engaging/disengaging from the engine. |
That makes sense, but I'm wondering what would cause it to happen or what I could do to fix it..
| Quote: | Don't know what make or model you have |
It's a 1996 CB500t, completely forgot to mention that.
| Quote: | try starting with the starter motor clutch assembly |
I'm not really sure what you're trying to say here
| Quote: | It does seem odd that an oil change (assuming it's the right oil for the engine) would be the cause, were there any starting problems before? |
To clarify; I went to start the bike so I could go buy some oil for the change, which I've yet to do. Nothing has changed or been done to the bike since it was last running about 2 days ago, and I wasn't having any problems with it then.
Thanks for the reply, it's given me something to look into. Back to google.. ____________________ Current: VFR800 2008 13.7k and rising rapidly!
 Ed Case World Chat Champion
