Does anyone know what the new test rules are from 2013?
brows91
PostPosted: 14:29 - 06 Jan 2012    Post subject: Does anyone know what the new test rules are from 2013? Reply with quote
I'm a learner rider and I'm going to do my test this year if I get the money. But as a back up plan, I was going to wait until next spring, which is just before my current CBT runs out and I'll be 21 so no restriction will be needed.
But if the new post test rules are implemented before then, I'm not sure what would happen after I pass.
Any help would be appreciated
Callum
steven_191
PostPosted: 15:06 - 06 Jan 2012    Post subject: Reply with quote
Whatever the current rules are when you pass is generally what you would go by. Hence why people who have a bike licence from the days when there was no test didn't need to take the test again. As far as I know anyway
PostPosted: 15:19 - 06 Jan 2012    Post subject: Reply with quote
tl;dr version - pass a test, any test, this year.
Long version:
We're still waiting for publication of the UK's implementation of 2006/126/EC - now pushing a full year late - but we know what it should say.
From January 19th 2013, the new licenses, ages and categories will be:
Arrow Sit A1 at 17, on an 125cc <=11kW bike, gives access to 125cc <=11kW bikes. Same as the current A1, which almost nobody sits.
Arrow Sit A2 two years after passing A1 or possibly at 19[1], on a bike of at least 400cc[2] generating between 25 and 35kW[3], gives access to bikes of any capacity up to 35kW.
Arrow Sit A two years after passing A2, or at 24, on a bike of at least 600cc[2] generating at least 40kW, gives access to any bike.
There will be no automatic upgrades between categories. In your case, if you leave it until next year then even at 21 you will only be able to sit the new A2 test, and even that's doubtful[1].
2006/126/EC states that nothing in it should remove entitlement from existing license holders. In your case, if you sit a "standard" bike test under the current 91/429/EEC. scheme and get an "A <= 25kW" license, there's no rational reason to believe that it won't automatically upgrade to full A after 2 years.
Notes:
[1] The DfT have indicated that they will give "direct access" to A2 at 19. However, 2006/126/EC does not list that as an allowed route to A2, it only allows for direct access to A at 24, or access to A2 2 years after passing A1. Since almost nobody currently has A1 that would mean that the earliest that anyone can sit A2 will be 2015. Exclamation
[2] The DfT have indicated that they may apply a common sense approach to the minimum capacity limits and allow a few ccs under, e.g. 396 or 596cc, just as they've now arbitrarily allowed some leeway in the 50kph Mod 1 speed tests.
[3] Technically an A2 test bike just needs to be at least 25kW. Whether it also needs to be under the A2 license limit of 35kW is not yet clear. This matters to training schools because if there's no upper limit then they can and probably will ditch their remaining 500cc bikes in favour of 600cc+ 40kW+ machines suitable for both A2 and A. If they have to retain lower powered machines just for A2, that adds more costs to schools that will already be struggling for business.
brows91
PostPosted: 15:39 - 06 Jan 2012    Post subject: Reply with quote
Thanks alot for that, looks like I should get saving to do my test this year!
I was going to post another topic but might as well include it on here:
I have been riding for over 3 years since I was 17 and riding a geared 125 for over a year now, I'm pretty confident with checks and maneuvers, do you think I'd be alright to do my test without training or would you reccomend to do a little training?
Daytona Paul
PostPosted: 16:01 - 06 Jan 2012    Post subject: Reply with quote
The attached .pdf has just been released.
Hopefully the '*training option' under the A2 and A categories will be allowed.
www.angliaroadtraining.com
CBT FROM ONLY £85
Back to Biking Refresher Day £99! Book with a friend and get 20% Discount!
UnspeedySam
PostPosted: 16:46 - 06 Jan 2012    Post subject: Reply with quote
The training option thing does sound like an interesting get out clause. I would guess that it would take the form of a CBT style day course.
It does still mean that you can't get a bike with any real power until you're 21 though. Which is a massive pain...
PostPosted: 16:47 - 06 Jan 2012    Post subject: Reply with quote
Cheers, very interesting. Got a source for that? I take it that's an "early" (in the sense of only being a year late) heads up to ATBs?
Well, ruh roh, there is indeed no "direct access" to A2 listed. I guess someone at the DfT has actually read the Directive since their 2010 consultation. Rolling Eyes
If that's really going to be the case though, then it's a massive ball-punt to riders, training schools and dealers, since the moment it comes in, the only available licenses will be A1 (125cc) and full A at 24. No new rider in the 17-23 age bracket will be able to sit A2 (and thus get a license for anything bigger than a 125) until 2015, and that's if any of them bother to pass A1 in 2013. Shocked
The DfT's 2010 consultation response had previously nixed the idea of access through training - the actual intent of 2006/126/EC! - in favour of full tests at each category for the rather bizarre reason of "cost". For some reason, they seemed to think that a test route costs less - apparently they think that fully insured big bikes just materialise at the test centre. It'll be interesting to see if and how they're going to backpedal on that.
And hello, it does say a 35kW upper limit on A2 test bikes. Great, so schools will have to run fleets of both A (40kW+) and A2 (25-35kW) bikes. Sick
Although since it looks like nobody will be able to sit A2 until 2015 they can at least postpone the pain until then. If there are any of them left in business by then. Pale
UnspeedySam
PostPosted: 16:53 - 06 Jan 2012    Post subject: Reply with quote
There is a DAS to A2: "Or must hold a valid CBT and theory test certificate and take practical test."
Also, it stands to reason that a fleet of 600s will be bought and then have the FI remapped on the fly for the different tests. At least that is how I would do it.
Daytona Paul
PostPosted: 16:55 - 06 Jan 2012    Post subject: Reply with quote
Rogerborg, it has been sent out to ATB's as a newsletter, cant find a link to it on any of their websites yet. Will probably appear during the next week or 2.
CBT FROM ONLY £85
Daytona Paul
PostPosted: 16:58 - 06 Jan 2012    Post subject: Reply with quote
Can't really see that being an option tbh. How will the examiner know that the bike is producing the 'correct' horsepower?
CBT FROM ONLY £85
UnspeedySam
PostPosted: 17:00 - 06 Jan 2012    Post subject: Reply with quote
How will the examiner know the bike is producing the 'correct' horsepower in any case? Are you referring to the stickers that FI international hand out with their kits?
Daytona Paul
PostPosted: 17:02 - 06 Jan 2012    Post subject: Reply with quote
beechbone, if we will be able to restrict a 600 for A2 what is to say that we have deristricted it for DAS?
I like the cost savings that only having to purchase 1 bike will give, but can't see the DSA taking our word for it that the FI mapping has or has not been changed correctly Wink
CBT FROM ONLY £85
UnspeedySam
PostPosted: 17:08 - 06 Jan 2012    Post subject: Reply with quote
Fair enough. I see your point. I just can't see how the riding schools are possibly going to economically buy bikes for these tests.
What would you suggest for the 33bhp-46bhp bike? I can't think of any that are currently in production.
Sorry if I'm coming across as a bit of a know it all...this stuff just rubs me up the wrong way. Even if my test is over and done with and I'll have a full licence in just over a year, I have friends who are quite likely to get caught up in all this.
Daytona Paul
PostPosted: 17:33 - 06 Jan 2012    Post subject: Reply with quote
Me neither.
We will probably end up just buying 600's.
That will, obviously, mean that 19 - 23 year olds might find it difficult to find training for A2 if we all do the same Sad
CBT FROM ONLY £85
PostPosted: 18:27 - 06 Jan 2012    Post subject: Reply with quote
The G650GS and the new Honda NC700X/S both claim bang on 35kW. Other than that, you're looking at the last of the GS500s, or any of the other 500s very slightly restricted - if you think they're actually still making over 35kW at the crank.
Given that vaguery I'd be hopeful that DSA examiners will take the candidate's word for it about the power of the bike. Heck, stuff a sock in the air filter, that'll get the power down for the test. I'm actually still hopeful that the upper power limit on A2 test bikes will just be stricken by someone with a bit of common sense.
Right, sorry, there is an implied a "direct access" to A2 at 19 via the test route (which the DfT had previously indicated they'd allow), but that only makes a shred of sense if the other route is via training-not-test 2 years after passing A1 (which wasn't previously on the cards).
I have the strong suspicion that the implementation is being kicked from pillar to post because none of the interpretations are good for the (general) bike industry. A training route would probably be the least bad option, as it won't look quite as horrible as having to pass the exact same test 3 times on 3 different bikes - or maybe even pass A2 and then A on the exact same bike.
Beelzebob
PostPosted: 18:43 - 06 Jan 2012    Post subject: Reply with quote
It's just occurred to me (apologies if it's been covered before)... are they going to extend the duration of theory test passes (currently 2 years) to cover the potential 8 years plus (16-24+) that it could take to pass all the relevant tests to get to a full licence?
The cynic in me says they'll make you do a new one every two years. 'Just in case anything's changed'.
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
PostPosted: 22:06 - 06 Jan 2012    Post subject: Reply with quote
I don't see how they could, since it's the same type of vehicle. This is the DfT under Mike Penning, not some gold plating socialista zombie.
Teflon-Mike
tl;dr
PostPosted: 22:31 - 06 Jan 2012    Post subject: Reply with quote
The table.. a lot of info that provides Rolling Eyes .. appears to suggest that you need a Theory Pass to gain first 'licence'; so if you follow the proscribed route; you would do Theory, then CBT, then test for A1.
(Note that the reqs for A1 test bike, have been raised to that of current A-restricted)
Having got your 'full licence' then 'progressive access' would merely demand a practical test or this notional 'upgrade by training'; so you wouldn't have to do another theory.
Direct access to A2 at 19, with CBT though and retaining unsupervised L-Plating makes a mockery of A1.
Would be better, and more in adherance with the EE Directive to 'Dum Down' the A1 and make that the new CBT.
So you turn up, do your days training; half way though get a propper off-road cone test, like the 'old' 80's 'Part 1', to let them take you on the road; hour of road-training, then final hour of 'test'... Wham-Bam thank-You maam; there's your A1... you can now legally ride a 125 on the road, no L-Plates.... come back when you want something bigger.....
But hey, when has there ever been any common sense in beurocracy!
snikks
PostPosted: 22:37 - 06 Jan 2012    Post subject: Reply with quote
Motorcycle candidates must always have a valid theory test certificate before taking their first practical motorcycle test. Unless they take the progressive access route, they must have a valid theory test certificate before taking any further practical motorcycle tests.
That part seems to me to say that if you take the "progressive" route, your previous license will be all you need - if you take the direct tests at any stage, a theory test certificate is required, obv.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
Beelzebob
PostPosted: 01:14 - 07 Jan 2012    Post subject: Reply with quote
Thanks guys yes it seems so obvious now... you'd only need it for the first full test.
Should engage brain before operating fingers, I suppose
JonWal
PostPosted: 08:42 - 07 Jan 2012    Post subject: Reply with quote
Hi guys i'm 28 years young. The missus has bought me Theory and put me in for my CBT with a local training school.
As long as I pass my full A test DAS before 2014 when they expire, will they both be valid to pass the new directive tests of 2013?
It's getting very confusing and I don't want to have to sit both again as it's unlikely I'll get money available this year now..
PostPosted: 11:47 - 07 Jan 2012    Post subject: Reply with quote
You'll (almost certainly) be fine. Direct access to a full A license post 2013 will be the same as now: CBT to validate your provisional entitlement; theory test; practical test(s) (we're probably going back to a single test at the end of 2012).
The only difference is that the age for DAS is going up to 24, and the test bike requirements are going up a bit as well, but neither will be a problem for you.
The full "A" license category itself will remain the same either way: any bike, any power.
bikertomm
PostPosted: 18:40 - 09 Jan 2012    Post subject: Reply with quote
Shit just got real Sad
https://www.motorcycletraininguk.com/eu_third_directive.html
The part that scares me is 'changes to be introduced Janurary 2012'
Guessing thats wrong..?
Boo. Thumbs Down
Teflon-Mike
tl;dr
PostPosted: 19:10 - 09 Jan 2012    Post subject: Reply with quote
Boo. Thumbs Down
Changes SUGGESTED Jan 2012 for implementation I think Jan 18th 2013.
That looks like a little scare-mongering propaganda by a School; suggesting 'worst case' scenario to drum up business.
https://www.bikechatforums.com//files/eu_third_directive_rules_for_moped_and_motorcycles_to_be_used_from_19_jan_2013.pdf
Paul's link is to the actual Whitehall release.... late by only a year, they manage to publish an A4 'table', with some suggestions about 'Progressive Access' saying that basically they STILL haven't got a fucking clue what they are going to do!
That HighWycombe training school suggests that 'Progressive Access' will require you doing Theory/Haz + CBT, then,
Mod 1 & Mod 2 on a 125 for A1 & waiting two years; then
Mod 1 & Mod 2 on a 400 for A2 and waiting two more years, then
Mod 1 & Mod 2 on a 600 for full A
Or doing DAS.
Also suggests that 'training' is mandatory for each upgrade.
BUT; actual Whitehall release suggests that Progressive Access MAY be by training INSTEAD of test; and currently its in debate whether Mod 1 will be scrapped and incorporated into a single part test again.
But as yet; we are still awaiting on 'propper' white paper proposals to go before parliment
bikertomm
PostPosted: 19:18 - 09 Jan 2012    Post subject: Reply with quote
Oh my, cheers for clearing that up Mike.
I think it's fairly clear the quicker you can get the tests out the way the better. Thumbs Up
The last post was made 14 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 142.83 Kb
