jimmypnc30 |
 jimmypnc30 L Plate Warrior
Kickstart |
 Kickstart The Oracle
 Posted: 22:29 - 10 Apr 2004 Post subject: |
Low CO probably means a lean mixture. However at idle this will not be affected by the needle jets.
Check for air leaks after the carbs. I understand that with the NC30 the recommended way to balance the carbs is to use needles in the carb rubbers, and then connect the vacuum gauges to these. This always struck me a slightly damaging, so check for a large number of holes from people doing this.
jimmypnc30 |
Kickstart |
 Posted: 10:52 - 11 Apr 2004 Post subject: |
Is the engine standard?
Wonder if the slides are sticking slightly in the carbs.
If the carbs are working fine then at the bottom end of the rev counter the mixture is dependent on the idle mixture adjustment screws, then the needles come in to play, up to the main jet at the very top. Any air leaks will have their greatest effect at low revs.
jimmypnc30 |
Robby |
 Robby Dirty Old Man
jimmypnc30 |
The last post was made 21 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
