| Ribenapigeon |
 Ribenapigeon Super Spammer
| FBSF |
 FBSF Nitrous Nuisance
 Posted: 16:19 - 19 Mar 2012 Post subject: |
If you can hear / see it running, and know what to look for regarding what would be required to pass the MOT, then yes.
Otherwise, it could turn out to be more expensive than buying a taxed/tested one.
Even if it "flies through", you'll still need a set of tyres (£120ish), Tax (£50ish) and an MOT (£30ish) so straight away you are looking at £200 extra.
And that's before it has a full service (Oil, filter, air filter, plugs, brake fluid) which even if you do it yourself is going to cost £50-70. If you have to take it to a dealer, you are looking at £150-200 for that.
And if it's been sitting for 2 years, it's going to need it.
Which is then an £650-800 bike.
If you are confident in doing any work on it yourself, it could well be a bargain depending on its mileage. If not, I'd leave it be. |
| Frost |
 Frost World Chat Champion
| Amreet |
 Amreet Trackday Trickster
 Posted: 17:02 - 19 Mar 2012 Post subject: |
Consumables are expensive and most of us have learnt the hard way that a 'cheap' bike usually works out to be the most expensive one. Tyres, filters, fluids, pads, cables, battery, it all adds up into a lot of money very quickly and the likelihood is you could probably find a far better example around the £700 mark that has been looked after, used and kept maintained.
Up to you which way you do it really, in some ways I kind of prefer doing the consumables my self, for exmaple I went and looked at some bikes that were advertiseds as 'new tyres, fluids etc. freshly serviced yadda yadda' that had been put back on the road for the bare minimum and probably done badly, horrendous chinese tyres, bike was a mess really so in that case I'd rather budget slightly higher to do the work myself and do it well, then you can have confidence in whats gone on/in the bike and it can also give you a good idea of condition. |
| Shinigami |
 Shinigami World Chat Champion
| Ribenapigeon |
| Rogerborg |
 Rogerborg nimbA
 Posted: 18:10 - 19 Mar 2012 Post subject: |
Spares-or-repair = £300 tops. If the seller wants more, let them put the time and money in. ____________________ Biking is 1/20th as dangerous as horse riding.
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 19:57 - 19 Mar 2012 Post subject: |
If you do get the chance to try and start it and it doesn't fire, try pulling the clutch lever in.
My neighbors' ER5 had been left for a couple of months, over winter, and wouldn't fire, pulling the clutch in, it fired straight away, presumably there was damp in the switch. ____________________ "Everybody needs money, that's why they call it money!"  |
| Chris750 |
 Chris750 Brolly Dolly
| Bomberman |
 Bomberman World Chat Champion
 Posted: 20:25 - 19 Mar 2012 Post subject: |
| Chris750 |
| Bomberman |
| herulach |
 herulach World Chat Champion
| Cheeseybeaner |
 Cheeseybeaner World Chat Champion
 Posted: 18:35 - 21 Mar 2012 Post subject: |
| FBSF wrote: | If you can hear / see it running, and know what to look for regarding what would be required to pass the MOT, then yes.
Don't see why it would necessarily need a new set of tyres. I have a bike which is mostly sat around and hasn't had its tyres changed in three years, no issues with them whatsoever. |
| Benson_JV |
 Benson_JV World Chat Champion
| Bomberman |
 Posted: 19:03 - 21 Mar 2012 Post subject: |
Hmmm, I don't think the GS's I did my training on did? ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| Bomberman |
| herulach |
| Bomberman |
| Cheeseybeaner |
| Pete. |
 Pete. Super Spammer
 Posted: 19:28 - 21 Mar 2012 Post subject: |
£400 isn't a bad price for a basically sound bike but as above if it needs tyres and a chain & sprocket kit you'll have doubled your spending once you've got it MOt'd and the other bits done.
At least it should be cheap to run, last a long while and sell on easily. ____________________ a.k.a 'Geri'
| _Troy_ |
 _Troy_ World Chat Champion
The last post was made 14 years, 197 days ago. Instead of replying here, would creating a new thread be more useful? |
