Conking out and fouling plugs
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Hex
Party Boy
PostPosted: 17:00 - 19 Apr 2004    Post subject: Reply with quote
I don't know the bike, however the things I would check would be:
Arrow Oil mixture, if it has an injector for it make sure its set right and that it isn't allowing too much in.
Arrow Fueling is set to rich.
Arrow Air filter blocked up,
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Hex
Party Boy
PostPosted: 19:55 - 19 Apr 2004    Post subject: Reply with quote
With a choke on it won't run right, just make sure you turn the choke off as soon as you can.
As for riding off when its cold, it wont feel right as it simply is cold, tight and not up to operating temperature, just don't thrash it when its cold.
rizzla
PostPosted: 21:24 - 19 Apr 2004    Post subject: Reply with quote
sounds like it is running rich and when you open the throttle your flooding it. when it gets warm its burning fuel correctly because its at its optimal temperature. check what hex said and maybe the float level.
PostPosted: 00:39 - 20 Apr 2004    Post subject: Reply with quote
I would agree with Hex. Sounds like it is running rich.
Thrashing it from cold will not wreck the plugs. In fact it would probably help the plugs. However it will also shorten engine life, and on some bikes is likely to provoke a cold seizure.
Leaving the choke on for too long will wreck the plugs.
Personally I would say get all your gear on, start the bike and ride off immedialty, as soon as it will run safely, then knock the choke off as soon as you can.
Also check that you are using the right grade of spark plug.
The last post was made 22 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 53.86 Kb
