Bandit 400 Carb Balancing Problems
rider_rob
PostPosted: 17:47 - 10 Apr 2012    Post subject: Bandit 400 Carb Balancing Problems Reply with quote
Hi all. 1991 limited edition Bandit 400 import.
Have cleaned (inc new o-rings) and balanced the carbs, but couldn't get them all to line up.
I found 3 screws: left screw did cyl#1, right screw did cyl#4, and middle screw did them all. #2 and #3 are not lined up and didn't move with any screw but the middle one, and then they went together?
I followed the manual but to no avail.
Any ideas before I hand it over to Suzuki for £55?
Budgetboy
PostPosted: 18:24 - 10 Apr 2012    Post subject: Reply with quote
The 1st screw balances number 1&2 together.. The 3rd one balances 3&4 together
The middle one balances them ALL together. 1&2 to 3&4
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
rider_rob
PostPosted: 19:21 - 10 Apr 2012    Post subject: Reply with quote
Thanks for the reply,
Any idea why the screws are not touching #2 and #3? When they are turned the dial for #1 or #4 moves, but the others stay the same?
Budgetboy
PostPosted: 19:38 - 10 Apr 2012    Post subject: Reply with quote
Do you have the carbtune set up correctly.
1st pipe to no 1 carb
2nd pipe no 2 carb and so on.
You balance carbs a little turn at a time. It take me about 2-5 mins to do them, but if you have never done it about 10 mins id say.
the screw between 1&2 will balance those 2
the screw between 3&4 will balance those 2
the one in the middle will balance 1&2 in line with 3&4
Casper
PostPosted: 22:52 - 10 Apr 2012    Post subject: Reply with quote
Under the screw and locknut you will have a plunger with a spring round if. Make sure its not stuck.
HD
PostPosted: 15:27 - 11 Apr 2012    Post subject: Reply with quote
The reason they are not directly connected is because they are on the throttle mechanism. As said, balance 1 & 2 together first (with the screw in between them). Make sure they are at the same level. Then go ahead and balance 3 & 4 again, to the same level with the screw in between. Then you balance both pairs together with the screw between 2 & 3.
rider_rob
PostPosted: 09:20 - 12 Apr 2012    Post subject: Reply with quote
Thanks guys, helpful comments!
The pic is what we got it to, which doesnt look to bad exept nothing we do adjusts the middle two. So we balanced 1 and 4 to them? The poilt screws have been messed with so need to re-set them also.
I'll try it again this weekend (when friend with tuner is around).
It may be that the springs are stuck and only adjusting one carb at a time? I did give them a proper clean, but not those screws. Afraid to mess the settings up too much really.
Will keep posted,
Thanks again.
HD
PostPosted: 09:51 - 12 Apr 2012    Post subject: Reply with quote
Video what you do if you can, I'm confused Laughing
EDIT: Confused at what he's doing, not how to do it
Budgetboy
PostPosted: 11:08 - 12 Apr 2012    Post subject: Reply with quote
Hey Confused
I have explained how to balance the carbs mate. There is 3 and only 3 phillips screws on the linkage for the carbs.
I think you must be doing something wrong imo.
orac
PostPosted: 11:20 - 12 Apr 2012    Post subject: Reply with quote
give me a couple hours or so and i will post the page in the manual that show where the balance screw are and how to balance them, it not hard.
those carbs are actually quite far off
https://www.youtube.com/watch?v=t0qf11BOx6o&feature=player_detailpage#t=182s
this vid should give you a rough idea of what you are supposed to be doing
orac
PostPosted: 12:16 - 12 Apr 2012    Post subject: Reply with quote
here
The last post was made 14 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 67.61 Kb
