2 stroke mix
Noggin
PostPosted: 20:55 - 20 Apr 2004    Post subject: 2 stroke mix Reply with quote
hi all, wondering if the 2 stroke oil mix on my NSR 125 RR is too strong with the petrol.
If there is too much, what can it do, and how can I adjust it?
Craig G(Noggin)
Current bike: kawasaki zx12r 2002
Track bike: yamaha r6 1998
Old Bike: honda NSR 125 1998
Irdawood the 2nd
PostPosted: 21:04 - 20 Apr 2004    Post subject: Reply with quote
There is a screw on the carb which if you turn will make the mixture richer or more lean.
Noggin
PostPosted: 21:05 - 20 Apr 2004    Post subject: Reply with quote
Thankyou
So is it all just trial and error to adjust the mix?
Craig G(Noggin)
Irdawood the 2nd
PostPosted: 21:13 - 20 Apr 2004    Post subject: Reply with quote
You shouldnt need to touch it at all, whats up with the bike? why do you feel that you need to change the mixture?
Noggin
PostPosted: 21:15 - 20 Apr 2004    Post subject: Reply with quote
Just an idea to see if can get a cleaner burn, so don't have to clean spark plug so often!
Craig G(Noggin)
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Noggin
PostPosted: 21:22 - 20 Apr 2004    Post subject: Reply with quote
Now I want to find out how to clean the carb now that you've said that.
What do you ride then Jammy?
Craig G(Noggin)
Hex
Party Boy
PostPosted: 21:35 - 20 Apr 2004    Post subject: Reply with quote
Oh no no no, if you set it too low you run a very good risk of seizing the engine.
There will probably be a setting ie 3 turns from when its fully screwed in , but I don't know what it is so wait until someone can tell you.
Hex
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Noggin
PostPosted: 21:37 - 20 Apr 2004    Post subject: Reply with quote
Phew, thanks, someone saved my bike, cheers Hex!!
Craig G(Noggin)
ProXimaCore
Dougal
PostPosted: 23:52 - 20 Apr 2004    Post subject: Reply with quote
According to the Honda NSR manual it's 2 and a half turns from closed. So screw it all the way in first. (not tight) then turn it anticlockwise 2 and a half times.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
PostPosted: 17:44 - 21 Apr 2004    Post subject: Reply with quote
cant you just put a smaller main jet in there?
thats probably the best way to sort out a rich bike..
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
PostPosted: 18:42 - 21 Apr 2004    Post subject: Reply with quote
The main jet only really affects the mixture after about 3/4 throttle. Basically the needle controls it from about 1/4 to 3/4 and the idle screw (and the shape of the cut out on the bottom of the carb slide) the mixture under 1/4 throttle.
None of those will have any effect on the amount of oil being pumped in. That is controlled by adjusting the cable going to the oil pump, which lives under a cover on the side of the engine.
Noggin
PostPosted: 19:30 - 21 Apr 2004    Post subject: Reply with quote
Cheers all, now I just need a manual, any going spare?
Craig G(Noggin)
The last post was made 21 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 79.47 Kb
