 russeleoin Nova Slayer
 Posted: 13:37 - 16 Apr 2012 Post subject: Trusty YB100 not healthy |
Hi All. I bought a new carb for my YB as the little fella(YB) seemed a bit down on power and the carb is definitly showing signs of wear. So I fitted it and now I have a strange problem. Starting the bike is a bit of an issue, it used to start on the 2nd kick, now it takes a while. Once started with the choke on, it is fine until it warms up, then it cuts out. Restart with the choke off and it will idle fine once warm but seems to have delayed acceleration, ie, twist and it takes a couple of seconds to rev. It didnt do that before. When warm and riding it feels down on power, but put the choke on and it is back to normal power but stop at the traffic lights and it cuts out. It will restart immeadatly with the choke off.
Now, I can go back to the old carb as I didnt have all of these problems, but it was not running as smoothly as needed hence changing the carb in the first place. I have checked the points, they are only a few months old, the gap is correct and the plug is good too. When running the bike is not running rich or lean. The battery is good, the only thing I am not sure of is the condenser? Do they degrade or just fail?
Thanks, Russ ____________________ I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer. |
 timmy222 Two Stroke Sniffer
 Posted: 14:24 - 16 Apr 2012 Post subject: |
Agh fek, thanks Timmy, now you mention it I didnt check the settings at all. I made sure it was clean, and just stuck it in. Shite what a dimwit.  ____________________ I love classic merc's but bikes take up less space.
