CG125 Oil Leak
mudcow007
PostPosted: 08:57 - 03 May 2012    Post subject: CG125 Oil Leak Reply with quote
morning all
working on my CG last night, i noticed a quite bad oil leak from behind the genny
im taking the engine out tonight so will be removing the genny at some point to check points etc
any ideas how would could be causing the leak?
im guessing its a crankshaft oil seal?, this is my first bike so im treating it like a huge learning curve
does it sound bad??
mudcow007
PostPosted: 18:48 - 03 May 2012    Post subject: Reply with quote
anyone?
lihp
PostPosted: 18:52 - 03 May 2012    Post subject: Reply with quote
probably worn seal, clean it up, then run the engine and see exactly where oil leak is developing from
Usher4566
It's not coming from near front sprocket or gear leaver does it run down sidestand
New cd200 benly owner
Walloper
PostPosted: 21:17 - 03 May 2012    Post subject: Reply with quote
Do they not use punctuation where you live?
mudcow007
PostPosted: 08:43 - 04 May 2012    Post subject: Reply with quote
thanks all
its definitely leaking from behind the flywheel
does this mean a full strip of the engine??
if i do open the case will it all just fall to bits??
i have the haynes "book of lies" but i haven't yet found where it mentions this seal
bikenut
PostPosted: 12:44 - 04 May 2012    Post subject: oilleak Reply with quote
Karma hi dude,
you have a manual. but find your bike on cmnsl and see the great exploded views, some pics of your base plate would be good, dont think even egn removal necessery on this bike, seal and large o ring?#
some pic would be good.
mudcow007
PostPosted: 14:31 - 04 May 2012    Post subject: Re: oilleak Reply with quote
bikenut wrote:
Karma hi dude,
how doo's!
cmnsl dont go back far enough for my bike 84/ 85 so i cant see.
i think i will just try an open the case when i get a chance to get the engine out
im just worried that as soon as i open it, it will all just fall to bits
tomh
PostPosted: 15:48 - 04 May 2012    Post subject: Reply with quote
If you're going to strip your engine down anyway watch this:
https://www.youtube.com/watch?v=XNX1Im0CBhc&feature=related
That should be more or less the same as your points engine. Since it's not in English just read along with your Haynes and you will see how simple it is to rebuild.
mudcow007
PostPosted: 16:06 - 04 May 2012    Post subject: Reply with quote
Karma
fantastico
it doesn't look that scary in there
cheers
The last post was made 14 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 14 - Page Size: 63.44 Kb
