I gone did a boo boo
Bred2shred
PostPosted: 21:16 - 06 May 2012    Post subject: I gone did a boo boo Reply with quote
I broke the end off the exhaust stud while removing the exhaust for a tart up on my XR125.
My first instinct is to heat up the block a bit and then try to undo the stud wth some mole grips.
Any other techniques without having to buy any specialist tools?
Evil or Very Mad
https://i48.tinypic.com/eukapi.jpg
I'm not as think as you drunk I am.
Raffles
PostPosted: 21:43 - 06 May 2012    Post subject: Reply with quote
Heat & Molegrips is probably a good option at this stage.
If, however, you're not in a big rush to complete the job then you should also consider using a dismantling fluid such as PlusGas over a period of a couple of days.
Quote Me Happy
PostPosted: 21:47 - 06 May 2012    Post subject: Reply with quote
Or cut a slot and use a screwdriver but a soaking in Plusgas is definitely a good idea.
fraggie
PostPosted: 22:35 - 06 May 2012    Post subject: Reply with quote
get a bigger nut and weld it on good.
The heat should break loose the bond between the bolt and the cilinder (after cool down)
then use a wrench to back it out. (worst case it'll break flush with the cilinder so you can drill and tap)
Pete.
PostPosted: 23:45 - 06 May 2012    Post subject: Reply with quote
That isn't going to work on a stud so tight it snaps whe you try to turn it.
a.k.a 'Geri'
Sako
PostPosted: 00:00 - 07 May 2012    Post subject: Reply with quote
get it to a garage, they have access to acetylene torches etc to get a bit of heat onto it.
Ichy
PostPosted: 00:08 - 07 May 2012    Post subject: Reply with quote
This rarely works. Look at the picture. That fracture looks like the stud is hardened. Weld a nut on it and it will most likely snap straight off.
The easiest thing is to run the engine until it is nice and warm and then try the mole grips.
Bred2shred
PostPosted: 00:09 - 07 May 2012    Post subject: Reply with quote
Cheers for all the ideas folks.
I've ordered up some plusgas and and I'll apply it every night this week and then try some heat and big mole grips at the weekend.
I don't think I want to start butchering the manifold flange and at present I don't have access to a welding plant but this may have to come into play if the above fails.
Cheers again guys, I'll let you know how I get on.
PostPosted: 00:21 - 07 May 2012    Post subject: Reply with quote
If you can grind a flat onto 2 sides so the grips grip better.
bikenut
PostPosted: 11:50 - 08 May 2012    Post subject: broken stud Reply with quote
:karma: hi dude,
sheared off cause its corroded into head. :D
weld stud to remains and file to fit over clamp plate.
Matt578
PostPosted: 18:15 - 08 May 2012    Post subject: Reply with quote
Stud extractor?
Some will grab some pretty short studs Wink
Your Daddy, Everyone's Friend.
Raffles
PostPosted: 19:32 - 08 May 2012    Post subject: Reply with quote
Matt578 wrote:
Stud extractor?
He said that he didn't want to purchase any specialist tools.
doggone
PostPosted: 20:36 - 08 May 2012    Post subject: Reply with quote
Best tip, if you can get in there.
At least there's a decent length to work on - so far Laughing
MaybeGuy
PostPosted: 22:30 - 08 May 2012    Post subject: Reply with quote
give it a few whacks from various directions to shock it free. It's saved me a couple of times. Or get a stud extractor socket set. you've got loads of meat for it to grip on.
Bred2shred
PostPosted: 23:13 - 08 May 2012    Post subject: Reply with quote
Cheers guys, loads of good tips there.
I do own a proxxon dremel type tool so will be able to put some edges on the stud before attempted removal. So along with a few wacks from a hammer, a soaking with plusgas and some heat from a butane torch it should practically fall out. Cool Laughing
0l0dom0l0
PostPosted: 23:19 - 08 May 2012    Post subject: Reply with quote
While you still have some stud left, I'd run a tap over whats left to make a longer thread and get a proper stud extractor on it.
If you heat it up nicely after you've tapped it and before you stick the stud extractor on it should come out.
While I appreciate you don't want to buy and specialist tools, it'll be cheaper to buy a stud extractor and a tap than pay someone to drill it out (which you'll have to do if it doesn't work). Exhaust studs you do once and do them properly. Don't get any second chances.
Bred2shred
PostPosted: 20:09 - 09 May 2012    Post subject: Reply with quote
Hey guys.
Got the thing soaking in plusgas and my dad dropped off his blow torch tonight.
What 0l0dom0l0 said has been playing on my mind and i've always been an advocate doing a job right the first time. So after watching THIS and seeing the success using this type of stud extractor i'm going to invest in one, i'll bet this is not the only time i'll need to use it.
I'll post up how i get on.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
0l0dom0l0
PostPosted: 12:33 - 10 May 2012    Post subject: Reply with quote
Bred2shred wrote:
Hey guys.
Yeah, that guy makes it look really easy and no doubt as you say there will be times when you might need the tool again.
Still heat it up nicely though, and the cold water in the syringe that chris pointed out will reduce the chance of it snapping even further.
BanditsHigh
Worse than a woman
PostPosted: 07:58 - 05 Jun 2012    Post subject: Reply with quote
Like everything else in life, what works for one person will not work always work for you.
The stud in the video link you gave above showed a stud which was not seriously corroded into the head ... the ease with which the stud was undone shows that ... that and the fact he used a chuck which is the most likely to slip with a corroded in stud!!
Heat, penetrating oil and time are your friends.
Welding a nut on causes thermal shock which tends to break the cold weld (corrosion between the steel and ally), meaning you should then be able to undo it with a ratchet ... but again this might not work in your case.
Stud extractors (of the cam wheel/ratchet type not eazi-outs) are good in that the more power you put into trying to undo the stud the harder it will grip ... once again though it might not work for you.
At the end of the day, no matter what technique you use, if the stud doesn't come out then you will need to drill and tap.
Good luck Thumbs Up
All the best ... Barry
Johnser
PostPosted: 10:49 - 05 Jun 2012    Post subject: Reply with quote
first off, dont get too concerned with trying to expand the block more than the stud. you'll be unlikly to be able to as its a massive heat sink and the stud is more or less well insulated.
Dont worry though, the point of heating is not to expand the hole so that the bolt slips out loose, its to crack the corrosion between bolt and hole. this is why welding onto the bolt works so well.... and it does work well.
bearing in mind you dont want to buy anything specialist (like a welder Very Happy ) first off I'd wind a nut onto the remaining threads until its quite tight. then soak for however long you can afford in the plus gas when it arrives, then heat the stud until its just glowing, then quench the stud with plus gas.
It is certainly worth giving the stud a few whacks at this point too.
now the nut you jammed on the remaining threads might just be stuck enough to let you wind the stud out using it. clamp it really tight using mole grips and it'll grip even harder.
Dont be tempted to just wind it straight out as soon as it starts to move - theres a good chance it'll bind again and shear as the heating will have softened it a bit too. instead, work it out; back and forth using the plus gas to help ease it.
good luck!
The last post was made 14 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 117.21 Kb
