Front wheel a little wobbly
neil5110
PostPosted: 20:12 - 22 May 2012    Post subject: Front wheel a little wobbly Reply with quote
Hey,
Recently changed the fork oil and seals on my 1997 CG125, and after putting everything together, noticed that the feel of the ride was a little off.
When pressing down on the front forks, I can see that the front wheel moves ever so slightly to the left (it pivots left around the axle, as opposed to just parallel sideways).
I also span the wheel and it seems to bulge one side, and then contract again.
I've checked wheel bearing, spokes etc. and none of these symptoms were happening before the fork oil and seals were changed.
Any ideas what might be the problem? Thanks.
Walloper
PostPosted: 20:53 - 22 May 2012    Post subject: Reply with quote
Missing a spacer from the axle.
Tyre is gubbed and has a soft/damaged sidewall.
fatnfast
PostPosted: 21:26 - 22 May 2012    Post subject: Reply with quote
Its worth checking you have relocated the speedo drive correctly as well.
neil5110
PostPosted: 07:26 - 23 May 2012    Post subject: Reply with quote
All these things seem fine on it =/
As far as I am aware, all the spacers are there, I refered to manual for a diagram, and looks fine.
Nick_Giles
PostPosted: 23:41 - 24 May 2012    Post subject: Reply with quote
I have had the front wheel off a CG. If it was missing a spacer it would be massively obvious. The spacer is quite a size.
When you replaced the spigot back in is it possible you damaged a bearing when doing so.?
Also disturbing a bearing that's on its last legs can be the final straw in their demise.
Nick.
neil5110
PostPosted: 09:40 - 25 May 2012    Post subject: Reply with quote
Ah, might be a damaged bearing then. They aren't expensive, so I guess it's worth the replacement?
Thanks Nick Smile
Nick_Giles
PostPosted: 10:37 - 26 May 2012    Post subject: Reply with quote
Nope, they aint.
For a CG they will be less than a bag of fish & chips. Smile
Nick.
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.07 - MySQL Queries: 14 - Page Size: 50.94 Kb
