Bike being stood - what next advice * DONE and WORKING *
map
Mr Calendar
PostPosted: 21:23 - 25 May 2012    Post subject: Bike being stood - what next advice * DONE and WORKING * Reply with quote
A mate's ST1100 has been stuck on his drive for some time. Judging by the last tax disc that'd be quite some time, Anyhow it was in gear. A group effort has just managed to get it nto neutral.
Given bike stoop for so long what's the next steps?
Bike not started.
Thanks in advance.
Suntan Sid
PostPosted: 21:36 - 25 May 2012    Post subject: Reply with quote
Change all fluids, check all fluid pipes for leaks, might be tempted to dribble a bit of oil down the bores before you turn the engine over.
Clean carbs, petrol tank and filters.
Might want to turn the engine over by pushing it along, slowly, while in gear, before hitting the button.
Walloper
PostPosted: 21:38 - 25 May 2012    Post subject: Reply with quote
Drop the oil.
Change the Oil filter.
Fill with fresh oil.
Check the air filter.
Empty and fill the tank with fresh fuel.
Clean out the carbs.
Check coolant.
Probably needs a new battery but the battery fitted may take enough charge to let you phaph about starting.
Try to turn the engine over at low RPM.
If no leaks, bang, crunches or whistles then allow it to warm up.
Depending on how long long is there could be rubber damage too. But you won't know till it appears or if it looks suspect replace with new.
temeluchus
PostPosted: 21:55 - 25 May 2012    Post subject: Reply with quote
I would replace the sparkplugs and make sure the HT leads arent rotten as well.
Casper
PostPosted: 22:10 - 25 May 2012    Post subject: Reply with quote
I was told if stood for over a year you could also use coka cola or oil. Put about 5ml down each plug hole and let it sit overnight and next day turn motor by hand.
Sounds like your clutch plates could also be stuck. Get new plates or try and free what you have.
Walloper
PostPosted: 08:02 - 26 May 2012    Post subject: Reply with quote
Rolling Eyes
I heard if a Black Cat walks across your path it is lucky.
Or is it unlucky?
For the cat or for the person?
What if it's a crowd?
What if the cat has one white paw?
What if......
The only really 'active' ingredient with respect to cleaning agents in coca cola will be the Phosphoric Acid.
But I would not consider pouring water into an engine. You will still have the task of flushing that shit out once it becomes emulsified.
If you need to clean the engine then just use a cheap oil. The movement of the engine parts will remove, mostly, any stuff that shouldn't be there. The cheap oil should carry it away when drained.
Casper
PostPosted: 11:05 - 26 May 2012    Post subject: Reply with quote
I see what you are saying with this however as I said “I was told” as it happens it’s an old house wife’s trick for engines that the piston rings are stuck to the bores. There is quite a lot of discussion on it with some for and against. One bloke goes on to say tomato sauce does the same job however this is for engines that have sat in a barn for many a year and is in need for restoration. The OP does not say how long his engine stood but I would doubt it’s been 10+ years so a bit of oil would be a good idea.
stevo as b4
PostPosted: 14:23 - 26 May 2012    Post subject: Reply with quote
If it's been sat a year or so, then yeah it would be good practice to drop a tablespoon of oil down each plughole, and while the plugs are out clean them and gap them to spec. Turn over the motor with no plugs in after the oil change and a new filter fitted. It will spin up quicker on the starter and should build oil pressure fairly quickly, so that the valve train has lube from the moment you start it up.
Most engines that have sat for years and have sticky rings, will still start fine, it's just they smoke a bit for a while. My ZX6R was sat for 4years without ever being started and run. As long as you have got plenty of clean oil in the sump, i see no issues with worrying about sticking rings. different matter if the motor won't turn over though.
map
Mr Calendar
PostPosted: 19:54 - 27 May 2012    Post subject: Reply with quote
Thanks guys for the advice.
More or less as I thought but nice to get a consensus and 2nd opinion.
Nice heads-up about the rubber hoses and connections. Not sure if it has braided brake hoses but this might be a chance to check and change if needed. Will check all the other rubbers. I imagine the air box will be a pain (but aren't they always regardless of bike! Very Happy )
All oil will be dropped and replaced. Might only be with cheap stuff first as once proved running then it will get another fresh batch.
Dropping fuel will be interesting as the fuel tank lives in the belly of the beast. The big tank thingy on them is for the car sized air filter above the carbs. It keeps the centre of gravity lower, which on something like this has to be a good thing. So in order to take out the fuel tank it looks like a lot of dismantling need to take place.
Have to declare an interest as if this bike works I'll be taking it. So want to get it on the road for as little as possible (I'm tight like that Wink).
At the moment trying to get all the panels off to make like easier*. It can get through an MOT without panels just have to make sure all the electrics, brakes, indicators, etc. are in place and work. I've fought with VFR panels before but whoever designed the Pan-European was evil. I may start another thread on this as having major problems.
Thanks again and I'll post of progress.
*This is because in order to get at the back spark plugs you need the articulated plug socket that's in the OEM toolbit. Luckily bike still has it. No other tool will do with panels in place Rolling Eyes .
bikenut
PostPosted: 12:37 - 28 May 2012    Post subject: dormant bikie Reply with quote
:karma: hi dude,
all of the above but turn engine over slowly by hand with plugs out first, valves can and do stick ( open usually ).
if engine turns over ok by hand ( you can see the valves thru the plug holes usually ) whiz on starter.
after sure oil got to all engine bits, so everything nicely lubed, then try to start.
leave running on centre stand to check for leaks etc.
the clutch will probably be stuck, so leave on stand and allow to warm up properly. when hot, use clutch lever and listen to g/box noise..........does g/box noise stop meaning clutch free????
after warm up on stand, stop engine, select second gear and start engine, allow to run and hold in clutch.......use throttle to make transmission snatch, to snatch clutch free when engine hot.
do not just open the throttle, smash it into gear and fuck the box.......
alternatively, strip and clean the clutch, whilst there flush out the crank case.......clutch debris and sediment etc.......
Walloper
PostPosted: 13:01 - 28 May 2012    Post subject: Reply with quote
Tip.
If there was no issue before the bike was stood.
I would bet a pound the beast will be fine.
There may be some corrosion in the cylinder bores but it may not be too bad.
Really, an engine should be set up properly if storage is more than a year. This involves removal of plugs and pouring a measured amount of VOC down the bores. and turning the engine by hand.
The engine oil should be removed and the sump filled with a mix of engine oil and VOC.
All breathers, vents, inlet and exhaust ports must be sealed.
Marmalade
PostPosted: 21:06 - 29 May 2012    Post subject: Reply with quote
If it refuses to turn over and won't turn the engine by pushing it in gear then the alternator will be corroded, probably cracked and you'll need £300+ deep pockets to get another one.
This is if you want to remove the rear wheel, tank, bevel unit, rear subframe and a few other bits and pieces to be able to access it.
map
Mr Calendar
PostPosted: 11:50 - 01 Jun 2012    Post subject: Reply with quote
1888 wrote:
I was told if stood for over a year you could also use coka cola or oil. Put about 5ml down each plug hole...
Just revisiting this thread as bike is due to be picked up and fettled by someone with more tools and experience than I can muster.
Regarding above quote for anyone else reading this thread in the future. Never, never, ever put anything like water in a cylinder or a petrol tank. Can use oil (as suggested elsewhere above) and if needed rinse out with petrol.
Will post results of the operation to get this running.
Lone-Wolf
PostPosted: 12:34 - 01 Jun 2012    Post subject: Reply with quote
Wotcha.
I've just made a start on a bike that's been standing . . . . for the last forty years. The fellow bought it new, rode it to work for four years, then emmigrated to Australia leaving the bike behind in an outbuilding at the local pub. That was the last time it was taxed and tested.
https://www.moonshiners.org.uk/D144S/144stax.jpg
Cheers.
L.W. - www.moonshiners.org.uk
Walloper
PostPosted: 13:05 - 01 Jun 2012    Post subject: Reply with quote
Lone-Wolf wrote:
Wotcha.
Awe cool find. I think it will be exempt from MoT safety check too...
Lone-Wolf
PostPosted: 13:10 - 01 Jun 2012    Post subject: Reply with quote
Wotcha.
'Fraid not . . . it's a 1968 BSA Bantam D14/4S.
Cheers.
Walloper
PostPosted: 13:23 - 01 Jun 2012    Post subject: Reply with quote
Lone-Wolf wrote:
Wotcha.
Bugger.
https://www.visordown.com/motorcycle-news--general-news/bmf-raise-issues-with-mot-exemption/20715.html
"The fact that from the 18th of November, thousands of classic cars and motorcycles that pre-date 1960 will no longer have to pass an MOT is a concern, say BMF."
The last post was made 13 years, 251 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 102.96 Kb
