| Nick 50 |
 Nick 50 World Chat Champion
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| MG |
 MG Traffic Copper
 Posted: 21:22 - 25 May 2012 Post subject: |
Friend of mine did this and tried a repair with quiksteel. It didn't hold so he replaced the sump. You can get it welded as a permanent fix too.
It's one of those things you don't want to risk because if there's no oil, you've got no bike  ____________________
'03 Honda Cityfly 125 > '02 Honda CB500S > '98 Honda CBR600F |
| Walloper |
 Walloper Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 13:34 - 26 May 2012 Post subject: |
If you ground a prep in the sump, welded it, then files the plug sealing face flat it wouldn't matter that the crack was across the threads because it doesn't seal there anyway. Only problem is you risk wrecking the thread with the welding. ____________________ a.k.a 'Geri'
| Casper |
 Casper World Chat Champion
| Drake |
 Drake World Chat Champion
 Posted: 15:14 - 26 May 2012 Post subject: |
just get it welded with the bolt in, then take bolt out, run a tap down it then clean it up ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| Chalky. |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
 Chalky. World Chat Champion
| Nick 50 |
| Walloper |
| Nick 50 |
| bikenut |
 bikenut World Chat Champion
 Posted: 09:43 - 30 May 2012 Post subject: |
hi dude,
did you read the thread about torque wrenches............  |
| Rogerborg |
 Rogerborg nimbA
| chris-red |
| fatjames |
 fatjames World Chat Champion
| fatjames |
| Nick 50 |
 Posted: 11:22 - 30 May 2012 Post subject: |
The problem with buying another sump is finding the right one. Have looked on e-bay but none are the right ones. Only the FV/FW models have the same sump.
I can source a new one but they are £145 . ____________________ Current Bikes: ZX7r 97 (Black Beauty), VFR400 NC24 (The banana)
First bike: A GZ125 Lemon....... |
| Noxious89123 |
 Noxious89123 World Chat Champion
| woodie |
 woodie Derestricted Danger
 Posted: 06:35 - 01 Jun 2012 Post subject: |
i did this on a customers BMW as they has alloy sumps ..
i used QUICKSTEEL..
i emptyed the sump and cleaned it out..
then done up the bolt so the crack was open slightly i squashed the steel in then un done plug quick before the steel set i then wire brushed around the crack and put a load more around left for 30 mins to set ....and was fine....
i used quick steel to reaplace a chunk missing out of a head on a 306 and is still running now  |
| MG |
 MG Traffic Copper
 Posted: 09:51 - 01 Jun 2012 Post subject: |
| woodie wrote: | Hi
i used QUICKSTEEL..
You did it for a customer?
If I was running a garage I wouldn't even consider doing a bodge like that! ____________________
| Nick 50 |
| woodie |
| Walloper |
| Nick 50 |
 Posted: 15:21 - 02 Jun 2012 Post subject: |
Well applying quicksteel didn't fix it, just slowed the trickle right down
So lay on the garage floor (I need a lift I reckon) thinking, i'm gonna have to take it off. The only other bike I had semi took apart was my GZ, so this was a whole new level.
Took all the bolts out of the sump, bit fiddly but they all come out a breeze. I was hoping I could slide the sump out with out taking the exhaust off. Errrrr no........
Look at the exhaust bolts (oh oh) 4 are long hex nuts and weren't rusty at all. Again fiddly, but come off quite easily. The 2 in the middle were normal bolts and looked pretty rusty. Have read quite a few threads on BCF about studs snapping etc etc so was a bit wary.
Sprayed plenty of penetrating fluid, went home had a coffee and went back round (bikes in garage about 100 yards away). These were extremely bloody fiddly to get to without taking the radiator off, but waheyyyy got them off. One stuck to the stud and the stud came out but nothing snapped.
So bloody happy I ditched the halfrauds socket set and got a decent one.
Anyway, the sump. The crack has travelled quite far up the inside (will add pic soon). It looks like i'll need to quicksteel the inside to get the bike back on the road.
I have contacted some breakers about keeping an eye out for a replacement, waiting game now.
Now to get the sump in the bath for a good clean and destory more of the mrs new towels (I killed the old ones ). ____________________ Current Bikes: ZX7r 97 (Black Beauty), VFR400 NC24 (The banana)
| Nick 50 |
 Posted: 17:33 - 02 Jun 2012 Post subject: |
So the offending crack, turns out to be 2 cracks, no wonder it continued to leak.
https://i300.photobucket.com/albums/nn6/ElScampio/GEDC0527.jpg ____________________ Current Bikes: ZX7r 97 (Black Beauty), VFR400 NC24 (The banana)
The last post was made 13 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
