| ZephyrJoe |
 ZephyrJoe L Plate Warrior
| Stonefly |
 Stonefly Scooby Slapper
 Posted: 10:18 - 05 Jun 2012 Post subject: |
Interesting problem!
I had EXACTLY the same issue with a GT750 P5 Kwak in the late 90's.
I tried everything i could possibly think of, but never managed to trace the fault. I was ready to push the fucker into a disused quarry when a mate asked if wanted a complete wiring loom for a P5.
I bought the loom for the princely sum of a tenner, fitted it, and the problem went away, never to return.
Now, i don't know whether the new loom cured it, or the physical act of replacing it dislodged some corrosion on a connecter. I recall there were a few connecters with powdery blue/green corrosion, which I cleaned and treated to a blob of petroleum jelly.
I know it sounds pretty drastic, but it may be worth removing your wiring loom completely, cleaning every single connecter and blobbing with petroleum jelly as you reconnect it all. ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
| ZephyrJoe |
 Posted: 12:29 - 05 Jun 2012 Post subject: |
Thanks for your reply Stonefly.
I've got the multimeter out to have a stab at testing the plug caps and three measured at 5.13-5.17 ohms and one measured at 4.73.
According to various sites on the tinterweb it seems that 5ohm caps have a +/-5% limit, so 4.73 is on the absolute limit and with the resistor plugs I guess it explains why it might drop a cylinder when under load.
However, I'm not sure because all 4 plugs are wet after idling on 4 cylinders for 5 mins or so - my thoughts are heading towards a dodgy cdi unit or the other black box parked behing it. I'll see what a new cap does...
After that I'll get a new coil and see if one has half broken down.
Failing that I'll sell the bugger again because the previous owner said this bike has been looked after and so far I can't see any evidence of that. After a month of ownership I've hardly ridden it, and I need a bike I can ride! The last 4 cylinder I got broke down after a month too! I've always preferred twins and I think I should've gone for a 500cc twin now.
I really don't want to be replacing the loom... even if it easy, I haven't built a good enough relationship with this bike to have the inclination to bother with something like that  |
| Casper |
 Casper World Chat Champion
| ZephyrJoe |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 15:58 - 05 Jun 2012 Post subject: |
disconnect the coils and reconnect them, under load sounds like one may be braking down, i had a similar problem with a single cylinder engine would idle and rev to around 7k fine any further it would drop out and sound rough as hell,
corrosion on the plug was the cause fixed in 30 seconds (once i found it ) ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| ZephyrJoe |
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
