| Cgiow |
 Cgiow Derestricted Danger
 Posted: 18:31 - 09 Jun 2012 Post subject: Please can someone help me with my Honda cg please!!! |
Hello my names Martyn I have a 1996 Honda cg alittle wile ago I went through a puddle/pond :-/ and ever since she's been back fireing and juddering a lot and not running how she used to:-/ I got her a new exhaust and shocks, the air filter is damp but i don't think it's that?, I have taken the carb to pieces cleaned it all with cotton bud and air blower thingy lol, also emptied the fuel tank cleaned the fuel filter, she ran ok for abit turned her off and a hour or so later she was running bad again I'm getting a good enough spark and oil is ok got a full tank of fuel, don't think brake pads are rubbing although I did fit new ones last week but I'm sure it's not that, as I say she's popping and back fireing when I speed up and let the throttle go she does it, and iv done what I can think of and I'm now baffled :-/ can anyone help!! And I'm not sure about how the screws on the carb should be ? Can some one help  ____________________ M l poskitt |
| Usher4566 |
 Usher4566 Spanner Monkey
| Usher4566 |
| Cgiow |
| Usher4566 |
| Cgiow |
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| Cgiow |
| Usher4566 |
| Usher4566 |
| N cee thirty |
 N cee thirty Banned
| Robby |
 Robby Dirty Old Man
| Cgiow |
 Posted: 21:26 - 09 Jun 2012 Post subject: |
Better pic i hope but there is also little drops of water comming out of the pipe fron the engine  |
| Usher4566 |
| Cgiow |
 Posted: 21:56 - 09 Jun 2012 Post subject: |
Thank you everyone I'll soak the filter tomorrow, and try to get new plug as well can some1 tell me the best plug to get?  ____________________ M l poskitt |
| tomh |
 tomh Scooby Slapper
| Cgiow |
 Posted: 08:54 - 10 Jun 2012 Post subject: |
Ok thank you I have shortened my ht lead abit for cleaner wiring and sounds better already as its Sunday I can't get oil anywhere till tomorrow so I'll give her a oil change and new plug and air filter tomorrow if she's not any better I shall let you guys know, also tho on my carb I'm not sure where the screws should be the one under the carb I was told to tighten it up the undo it 2 full turns can anyone help  ____________________ M l poskitt |
| karthead |
 karthead Trackday Trickster
 Posted: 09:10 - 10 Jun 2012 Post subject: |
| Pete. |
 Pete. Super Spammer
 Posted: 09:22 - 10 Jun 2012 Post subject: |
If the bike was running fine before you went through a puddle, then don't touch the idle mixture screw. Why would you want to make adjustments to an engine that was running fine?
Get the air filter off and run the bike without it. If the bike now runs fine, your air filter is clogged.
If it's the foam type which you oil then getting it wet might restrict it because the oil and water will form an emulsion which will be held in the foam. To clean it, get a bucket of hot water with a good squirt of fairy liquid and wash the foam out thoroughly in the bucket, squeeze out the water and allow to dry, then re-oil, not forgetting to squeeze out the excess oil into a rag or some paper towel. ____________________ a.k.a 'Geri'
| spaz |
 spaz Nova Slayer
 Posted: 09:40 - 10 Jun 2012 Post subject: |
NOOOOOOOOOOOOO!!!
What you are referring to is the pilot jet; it controls the first 1/8th of throttle movement. As has already been said, do NOT adjust anything if the bike was running fine prior to the 'puddle' incident. ____________________ "If it's got tits or an engine, it'll be trouble" |
| karthead |
| Cgiow |
| karthead |
| Cgiow |
 Posted: 10:14 - 10 Jun 2012 Post subject: |
Ok so I'm back and quite wet lol but she is better without air filter but juddering a lot and feels like there's no fuel getting through but I ether pull throttle rite back and she goes or ease off to slow down, basicly she won't maintain speed without juddering  ____________________ M l poskitt |
| Cgiow |
The last post was made 14 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
