A n00b question about oil
yambabe
PostPosted: 16:15 - 10 Jun 2012    Post subject: A n00b question about oil Reply with quote
I've changed the oil on my bike all by myself today for the first time ever. Embarassed
Now I know most of you are already having a good old Laughing at me for being proud of doing something so easy but meh, we all have to start somewhere eh?
Anyway, what I wanted to ask was, I noticed as I dropped the old oil out that it started off really thick and black like treacle, but got cleaner as more came out. This suggests to me that all the crap settles to the bottom once the bike is parked up.
Being that oil is so thick by nature and often holds stuff in suspension I'm just wondering if anyone can explain to me in laymans terms why this is, why it doesn't just stay where it is? What is the dirty stuff made up of and where does it come from?
Sorry for the odd question Embarassed but the OH is out this afternoon.......
Hetzer
PostPosted: 16:18 - 10 Jun 2012    Post subject: Reply with quote
Did you let it out while it was still warm/hot?
T0MMY
PostPosted: 16:22 - 10 Jun 2012    Post subject: Reply with quote
Are you sure it wasn't just that the stream got thinner so less opaque? When you first pull the sump plug (and drop it accidentally into the washing up bowl) you have a thick stream of oil so it looks black. When it's down to a dribble it will look more golden as you can see through it.
I always drop the oil immediately after stopping the engine so if you did the same it should be pretty well mixed I'd have thought.
ZX6R + CBR600RR
jay12329
Dr. Evil
The crap is basically bits of engine and stuff from where the structure of the oil breaks down with heat/mechanical pressure.
The bits of metal and crap are heaver than the rest of the oil so over time they sink. They will sink slower in oil than water but they still sink (just like the glass in your house windows is flowing down the pane!)
It could also be as the oil level is getting lower you get a slower flow rate so the oil can look lighter in colour even if it isn't. Smile
Was the engine warm when you emptied the oil? Flows much better if it is Smile
J
yambabe
PostPosted: 16:38 - 10 Jun 2012    Post subject: Reply with quote
The engine was stone cold and the bike has been stood for a week.
I only dropped the spanner into the bowl, not the nut or the washer as well! Mr. Green
So do it warm next time? *makes note*
yen_powell
PostPosted: 16:46 - 10 Jun 2012    Post subject: Reply with quote
Get it warm, then remove the filler cap before undoing the drain bolt.
XT1200Z and a DR350 in bits
keggyhander
PostPosted: 17:01 - 10 Jun 2012    Post subject: Reply with quote
Not sure if serious
RhynoCZ
PostPosted: 17:15 - 10 Jun 2012    Post subject: Reply with quote
Do NOT remove the filter, if you don't have a new one as a replacement. Just drain it (warm engine helps, oil viscosity decreases with higher temperature), then change the filter (lube it if needed), don't forget to put the screw back and fill it up. Thumbs Up
Derivative
PostPosted: 18:00 - 10 Jun 2012    Post subject: Reply with quote
This is a well perpetrated myth.
Antique windows often look larger at the bottom because glassmakers just weren't as good as they are today. There are examples of the opposite being true (top of the window being thicker), it's just less common for various useful reasons.
https://www.sciencenews.org/sn_arc98/5_30_98/fob3.htm
The difference in thickness sometimes observed in antique windows probably results from glass manufacturing methods, says LaCourse. Until the 19th century, the only way to make window glass was to blow molten glass into a large globe then flatten it into a disk. Whirling the disk introduced ripples and thickened the edges. For structural stability, it would make sense to install those thick portions in the bottom of the pane, he says.
PostPosted: 18:43 - 10 Jun 2012    Post subject: Re: A n00b question about oil Reply with quote
yambabe wrote:
What is the dirty stuff made up of and where does it come from?.
Most is probably carbon blown past the ring
EazyDuz
PostPosted: 19:24 - 10 Jun 2012    Post subject: Reply with quote
Was that on a virago?
Had to use a hammer on a spanner to undo the drain bolt, ridiculously tight
Paris2
PostPosted: 20:35 - 10 Jun 2012    Post subject: Reply with quote
keggyhander wrote:
Not sure if serious
I would say serious
Current Ride: Daytona 600
The last post was made 14 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.06 - MySQL Queries: 14 - Page Size: 76.14 Kb
