Jumping chain
Richtea
PostPosted: 10:39 - 19 Jun 2012    Post subject: Jumping chain Reply with quote
Hi,
Just cleaning my chain this morning and let it run on idle in 1st gear just to circulate the oil.
The chain seemed to be jumping around a bit (video below). Is this anything to worry about?
I would hope that it is just because the chain is not under any load, as when I pick the revs up it seems to be fine.
Any reassuring comments?
https://youtu.be/5140l7KSnj0
Ps. Chain seems to be correctly tensioned
2005 Honda Varadero 125xl > 2005 GS500F > 2007 DRZ400 SM > 600 Bandit & Yamaha YP250
recman
PostPosted: 10:50 - 19 Jun 2012    Post subject: Reply with quote
Stiff links. Wink
doggone
PostPosted: 10:57 - 19 Jun 2012    Post subject: Reply with quote
Fairly normal I'd say, a new one might run smoother but as you thought it's the un-natural situation of no load plus running at tick over doing it.
cb1rocket
PostPosted: 13:55 - 19 Jun 2012    Post subject: Reply with quote
its the pulses from engine running characteristics. Every time the engine fires it does a sharp jolt then it slows down again You don't really notice this on the tacho because its so minor adjustment of engine speed.
Rev it a bit higher and watch again, it will smooth out.
Chain is fine anyway
Richtea
PostPosted: 14:11 - 19 Jun 2012    Post subject: Reply with quote
Thanks for all the info, looks like its nothing to worry about then.
Thanks again, help is appreciated.
Benson_JV
PostPosted: 15:47 - 19 Jun 2012    Post subject: Reply with quote
When I bought my first bike, the CBR, it did this. I went out & bought a new chain & sprocket set as I thought it meant the sprockets were forked. Laughing
Ed Case
PostPosted: 21:31 - 19 Jun 2012    Post subject: Reply with quote
Normal, on tickover the motor runs slightly uneven which makes the final drive sprocket 'snatch' causing this effect.
Fairies attack This post is not being displayed because the poster is banned. Unhide this post / all posts.
mentalboy
PostPosted: 19:18 - 20 Jun 2012    Post subject: Reply with quote
If you've got any concerns in this area try this!
Get some good old fashioned oil on it, if it's got a split link even better - get it off and soak it overnight, won't hurt to work it in with a scabby brush. Then leave it on some newspaper to get rid of most of the excess. After this it should be easy to check along it's length for tight spots, which may loosen up if you work them back and forth. Whilst it's off you could look up stretch tolerances for it and see if it's not overly stretched.
If you say it's correctly tensioned then go to rear sprocket and try to lift a chain link off the sprocket, the more it lifts off the sprocket the more likely you're going to need a new chainset.
Check the teeth on the sprocket for mishapes - always easier to reference against a new one if you're not sure what they should look like. But if you can use it to hook fish with or they finish in a nice sharp point then again you'll be wanting a new chainset.
Whenever you replace a chain always do the sprockets as well - you'll only end up knackering the new bit in double quick time.
Make mine a Corona.
paddlesat16
PostPosted: 19:41 - 20 Jun 2012    Post subject: Reply with quote
I think you have worn cush rubbers and a worn chain as well. You get sloppyness as the rear sprocket moves backwards and forwards in its hub.
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
orac
PostPosted: 20:06 - 20 Jun 2012    Post subject: Reply with quote
that normal for good old gs5s on tickover (from sound and what i saw of it) as said before its the engine pulses as it fires.
its does this while it being riden just not to that extent. you alos have to realise that there will be extra slack in the chain from it being on the main stand
oh and give your chain a good clean next time, as you clean it you can inspect it for stiff link and alike at the same time
Richtea
PostPosted: 23:15 - 20 Jun 2012    Post subject: Reply with quote
Cheers guys,
I'm gonna give the chain a going over tomorrow so I'll check all your suggestions.
Thanks Thumbs Up
The last post was made 13 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 71.27 Kb
