YZFR125 suspect low compression
stuartadair
PostPosted: 18:08 - 01 Jul 2012    Post subject: YZFR125 suspect low compression Reply with quote
Hello all,
I think I know whats wrong with this bike, however am hoping someone will tell me I'm wrong.
2009 Yamaha YZFR125
Riding 2 weeks ago in torrential rain. Bike cut out. Engine turns over but wont fire.
1. Plug looks fine and there's a strong spark.
2. Took fuel injector out and lay on top of bike on a cloth. I can see fuel squirting out.
3. Took air cleaner cover off and found about 1 cup worth of dirty water.
4. I can feel some compression in the plug hole, but I can keep my finger over the plug hole. When I try this on my sons 125 I cant keep my finger over the plug hole without it blowing off.
5. Tried firing up with Bradex but no sign of life.
6. Water level is fine and no sign of bubbles in radiator when bike is turned over.
I suspect that rainwater has been sucked into the cylinder and done some sort of damage, however I cant reconcile that with the fact I can feel some compression.
Any advice is welcome.
Thanks Stu
Ariel Badger
PostPosted: 19:14 - 01 Jul 2012    Post subject: Reply with quote
If water has entered the chamber it can hydraulic... bending valves, breaking rings and bending con-rods. Time to take the head off Sad I had it happen on a 500cc Armstrong, all it had done was loosen some carbon that held the Exh valve open Very Happy
lihp
PostPosted: 19:17 - 01 Jul 2012    Post subject: Reply with quote
How wet was the air filter? I can't imagine pulling that much water though a filter and air intake system to water damage the engine?
How is the bike treated? I'd do a proper compression check or remove the head?
stuartadair
PostPosted: 19:18 - 01 Jul 2012    Post subject: Reply with quote
thanks for the reply. I've resigned myself to taking the engine out later this week and stripping it down. Its going to be much easier then messing around in the bike.
I've downloaded a workshop manual and it should have 78psi so there's no way I should be able to keep my finger over the plughole - So definately low compression.
stu
stuartadair
PostPosted: 19:19 - 01 Jul 2012    Post subject: Reply with quote
The filter wasnt wet but there was a about a mug-full of water in the air box.
lihp
PostPosted: 20:12 - 01 Jul 2012    Post subject: Reply with quote
On the filtered side of the bo?
stuartadair
PostPosted: 20:21 - 01 Jul 2012    Post subject: Reply with quote
Yes, take the air filter cover off, remove the element and it had water in. The water was about 2 inches below the level of the intake pipe to the cylinder. Finding the water together with the other symptoms, partularly given that its meant to have 70+ psi and yet I can hold my finger over the plug hole when cranking says to me that something is amiss with pistons/rings/valves.
Stu
moonzoomer
PostPosted: 21:58 - 01 Jul 2012    Post subject: Reply with quote
The owner of this identical yamaha had the same problem, he also complained about difficult starting and high oil consumption LOL .
https://i1142.photobucket.com/albums/n604/mawlarky/MVC-003F-1.jpg
prawny1
PostPosted: 09:56 - 02 Jul 2012    Post subject: Reply with quote
It seems these engines are failing quite often I can't say it's bad manufacturing because we see them generaly with no oil in and given the fact that they only take about 1 litre of oil (yes thats for engine clutch gearbox everything) added to the fact that none of the owners complained of smoking of oily exhausts it could just be down to normal oil consumption and the owner not checking the oil level between services.
Some condensation in the airbox can be expected on most bikes and given the recent rain i would say you probably have drownd electrics more than anything, do you get a good spark?
just re read your first post and noticed you say you have a strong spark so probably not electrical, did you check with the plug out of the engine or a different plug?
hellkat wrote:
Some people are only alive cos its against the law to kill them.
stuartadair
PostPosted: 12:55 - 02 Jul 2012    Post subject: Reply with quote
Hi,
Yes, plug out of the engine and its a really strong spark. It was more than a bit of condensation in the airbox though. What made me initially worried was that it wouldnt even show any sign of life with a squirt of Bradex. I know we have fuel, we have spark. I also know that the compression feels very low and am suspecting a bent con-rod, hence the piston is not fully moving to the top of the cylinder. Will know more when I take the head off.
Have you taken the head off this engine in the bike before or would you recommend removing the engine ?
stu
moonzoomer
PostPosted: 13:17 - 02 Jul 2012    Post subject: Reply with quote
You can remove the head and barrel with the engine in the frame, its a bit fiddly but can be done. Check all 4 valves for bends and sealing once the head is removed. Every one of these engines I have seen stripped have all had chewed pistons and/or valves.
stuartadair
PostPosted: 12:55 - 05 Jul 2012    Post subject: Reply with quote
Hello all
I've just got chance to start looking at this engine. Took the crank cover off to see the crank timing mark and the water pump off to see the cam mark. According to the manual I have the mark on the crank aligns with a fixed mark on the cover to show TDC, and at the same time a mark on the cam aligns with a mark on the cam cover.
I found 2 marks on the crank, a single and a double mark so I'm not sure which is the correct one - Can someone please advise.
However, when the single mark is aligned the cam mark seems to be off its mark, and its worse when I align the double mark.
This photo is with the sinle crank mark aligned. The cam mark should be in the V on the cam casing cover.
Has anyone had these engines to bits before and can advise on the crank marks and if its normal to see the cam aligning in this way ?
Have a compression tester coming tomorrow to be 100% sure I've got issues in this area.
https://i997.photobucket.com/albums/af99/stuartadair123/IMG-20120705-00073.jpg
stuartadair
PostPosted: 13:24 - 05 Jul 2012    Post subject: Reply with quote
Bit more info...
Timing chain tensioner feels ok. Turn the screw to the right and I can feel the spring tensioning so I dont think thats the problem. It looks like the valve timing has jumped a notch though.
Not sure if 1 notch would be enough to kill most of the compression ?
P.
PostPosted: 15:15 - 05 Jul 2012    Post subject: Reply with quote
get.
the.
head.
off.
Saves ALL the guess work Laughing You'll soon see if a valve has been introduced to the piston.
stuartadair
PostPosted: 15:17 - 05 Jul 2012    Post subject: Reply with quote
I know you're right Paddy, I'm just trying to find any possible other solution in the hope it all goes away Laughing
P.
PostPosted: 16:46 - 05 Jul 2012    Post subject: Reply with quote
Ideally you want the compression back Wink
I'd whip it off straight away, you'll see if its damaged, would lol at half the piston missing Laughing
moonzoomer
PostPosted: 17:45 - 05 Jul 2012    Post subject: Reply with quote
Best thing is to remove the head for a look, but before doing that try backing of the valve clearances and check for tight clearances that could account for low compression and the bike not starting on the bradex.
stuartadair
PostPosted: 18:49 - 05 Jul 2012    Post subject: Reply with quote
Good call. I've checked the valve clearances and they are ok. I've no doubt that the compression test will show a low figure, just want to know how low before I take the head off. I'm a bit mystified about the valve timing being out too.
I'll update you when I take the head off tomorrow.
Stu
moonzoomer
PostPosted: 18:55 - 05 Jul 2012    Post subject: Reply with quote
Once you have removed the head leave the sparkplug fitted, turn the head upside down and fill the dish with petrol/turps /white spirit to check for leaks around the valves and seats.
russell210276
PostPosted: 20:00 - 05 Jul 2012    Post subject: Reply with quote
just a quick 1 from me 1 simple thing has been missed but im no expert Razz you said water was in the air box what about cleaning the throttle body incase the fuel has water mixed or am i thinking wrong with me been use to carbs if so ignore me Embarassed
stuartadair
PostPosted: 20:26 - 05 Jul 2012    Post subject: Reply with quote
Thanks for the suggestions gents.
I've taken the air cleaner completely off and tried to fire with Bradex. The bike's fuel injected and the injection system is working fine.
Stu
stuartadair
PostPosted: 12:01 - 07 Jul 2012    Post subject: Reply with quote
Here's an update for you. Took the head off today...
Barrel and piston both knackered. My biggest worry is that 1/2 the piston is missing and there's only one place it could be, down in the depths of the engine.
So, I'm either looking at splitting the crankcase to find the missing bit, full gasket set, barre and piston or a replacement engine. Am speaking to the lad that owns the bike later today to give him the good news Crying or Very sad
https://i997.photobucket.com/albums/af99/stuartadair123/IMG-20120707-00001.jpg
https://i997.photobucket.com/albums/af99/stuartadair123/IMG-20120707-00002.jpg
ThoughtContro...
PostPosted: 12:27 - 07 Jul 2012    Post subject: Reply with quote
Shocked
Are Yamaha making their R125 pistons out of cheese?
I've read of kids removing the limiter on the engine to enable the bike to exceed 84mph. Is this from a standard, unmodified bike or has a previous owner been dabbling?
Prize cunt
stuartadair
PostPosted: 12:47 - 07 Jul 2012    Post subject: Reply with quote
Hi,
The only mod thats its had is a non-standard exhaust. Rest of the bike is standard. If I could have found the missing 1/2 piston I'd be happy but I cant take the risk of it jamming something up when the bikes running.
P.
PostPosted: 12:55 - 07 Jul 2012    Post subject: Reply with quote
NO WAY!
The last post was made 13 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 124.69 Kb
