Aprilia RS125 - The Clutch...
TheBoyChris
PostPosted: 11:24 - 10 May 2004    Post subject: Aprilia RS125 - The Clutch... Reply with quote
Ok, been riding for about 3 months now, and the last month has been living biker hell. My Aprilia has been doing the following:
- Cutting out in low revs
- Cutting out when changing from neutral to 1st
- Overheating to the point of dumping coolant
- Gears locking/becoming stiff to change
- Accelerating (!) when clutch fully depressed and throttle applied
The person I bought the bike off changed the clutch cable just before I bought it, I'm guessing it's either (a) too long, or (b) stretched. Either way they clutch seems to always be touching, hence why all the above problems are occuring.
I wanted to run this by you guys before I spend even more money on this bike (already replaced both sets of brakes, both sprockets and a chain with 12 dry links...) I'm hoping I'm not going to need anything more than a cable, but with this happening for a month I can imagine there being a lot more damage that has happened because I never realised in time.
Thanks
Chris
Zx6man
PostPosted: 11:52 - 10 May 2004    Post subject: Reply with quote
the wifes RS did the same with the accelerating thing..I think they are just crap mechanical wise, so we got rid.
PostPosted: 13:03 - 10 May 2004    Post subject: Reply with quote
There is an adjuster for the clutch by the clutch lever, and another adjuster under the clutch cover accessed through a small hole in the centre of the clutch cover.
You should be able to adjust it to work properly.
The RS does tend to eat brake pads. I am not that hard on brakes but have only had the front pads last 4000~5000 miles a set.
TheBoyChris
PostPosted: 14:36 - 10 May 2004    Post subject: Reply with quote
Cheers Keith, I'll have a fiddle with that tonight. Here's hoping I'm not going to be asking where I can get a new clutch from by 9:00 Wink
Chris
PostPosted: 18:54 - 10 May 2004    Post subject: Reply with quote
Changing the clutch on an RS125 (late one at least) is very easy.
The last post was made 21 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 45.6 Kb
