Is it possible to adjust rear brake pedal height?
MacYam This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PsychoHippy
Jammy Git
PostPosted: 14:16 - 12 May 2004    Post subject: Reply with quote
It should be possible to make some adjustment, if you tell us what bike it is, someone may be able to tell you exactly how Smile
I spend all my money on bikes and beer, the rest I simply waste!
craigT19
Jolly Green Giant
PostPosted: 19:08 - 12 May 2004    Post subject: Reply with quote
you cant adjust the pedal it self, unless you rotate the whole foot rest assy but then your have a foot peg thats not straight.
under the rear brake your find a spring, follow that up a little and it is hooked to a big switch (large black thing just above the brake lever) your see a small plastic tread and a plastic bolt, loosen the bolt then get the pedal in to the position you would like the light to come on, then tighten up the bolt.
regards
Current bike : - 2016 MT-10
robbiehall
PostPosted: 19:17 - 12 May 2004    Post subject: Reply with quote
If the pedal fits on to a splined shaft, surely it is possible to undo the pinch bolt and slide it on in a diff position ??
Rob
The older I get, the faster I was.
craigT19
Jolly Green Giant
PostPosted: 19:23 - 12 May 2004    Post subject: Reply with quote
well i don't know about the yamaha, but when tried it on my ninja, i couldn't get the rear brake hydraulics back on the lever again..they didn't reach far enough Confused i probably could move it...but i seemed alot of work, so i just got out of the habit of resting my foot on the brake
robbiehall
PostPosted: 19:30 - 12 May 2004    Post subject: Reply with quote
Is this a question of the foot resting over the pedal all the time?
Annoying for people following !!
Could you not angle your foot outwards (point the toes out) ??
Rob
craigT19
Jolly Green Giant
PostPosted: 19:33 - 12 May 2004    Post subject: Reply with quote
that would be the easier option
carvell
Scuttler
PostPosted: 21:38 - 12 May 2004    Post subject: Reply with quote
Or, you could put your feet on the pegs properly!
Put the ball of your foot on the peg, touching the brake will not be an issue then, as your foot will not be near it.
Yamaha TDM 850
The last post was made 21 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 57.17 Kb
