help... suzuki rgv 125 engine prob
Trev987
PostPosted: 00:13 - 13 May 2004    Post subject: help... suzuki rgv 125 engine prob Reply with quote
Laughing Hello I’m looking for some help with my rvg 125 fun engine problem .it has blown a few spark plugs in its time. I came to it yesterday to find it won’t start at all. After a hour of messing with it I got it to run for 20 seconds max but it kept conking out, there is a good spark and it is getting fuel and oil fine .also the air filter is clear, it’s got me stumped at the moment any help with this would be great Thumbs Up Shocked
Robby
Dirty Old Man
PostPosted: 08:51 - 13 May 2004    Post subject: Reply with quote
How many miles on it? COuld be due a rebuild.
When it was running ok, was the powerband getting narrower?
Also try draining the carb, could have some water in.
Can I have your wheels?
priller
PostPosted: 14:32 - 13 May 2004    Post subject: Reply with quote
BTW its a RG125F.
Trev987
PostPosted: 15:12 - 13 May 2004    Post subject: Reply with quote
hello again its got about 17000 miles on it and its a n reg bike i think about 1995 ,the power band has been a constant power from 8000 revs but it did have a new one about 2000 miles ago and it will stutter when its cold.i had the carb off yesterday so thats fine so i'm still stuck. wots involved in a rebuild ?
Mad
Robby
Dirty Old Man
PostPosted: 17:10 - 13 May 2004    Post subject: Reply with quote
A rebuild involves getting the cylinder head and barrel off, and changing the small end bearing, piston and rings. Sometimes just the rings, but generally both. Costs about 60 quid and a days work if you do it yourself and use a decent pattern piston, more like 100+ if you use a genuine piston.
At 17000 miles if it hasn't had a rebuild yet its probably due. Where in the country do you live?
Trev987
PostPosted: 20:58 - 13 May 2004    Post subject: Reply with quote
thanks for the information,do you think a rebuild will solve the problem ?i live in preston lancashire
Robby
Dirty Old Man
PostPosted: 21:51 - 13 May 2004    Post subject: Reply with quote
Get the compression tested, should be over 120 PSI.
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 48.98 Kb
