zzr 600 clutch doing odd things any experience?
jimspeed
PostPosted: 09:34 - 19 Aug 2012    Post subject: zzr 600 clutch doing odd things any experience? Reply with quote
Ok it's an E5 if that matters, clutch started slipping at higher rpms so I checked the cable free play and there was no slack, adjusted it to about 4 mm at the bar and is fine no slipping BUT now when I rev it hard the slack moves out of the cable so the lever moves away . Ie if I change gear before 7k the 4mm play is there in the cable and if I rev it to 10k there is no slack and it's a bigger reach to the lever.
Anything common on these? Thinking I'll take the side off today and take a look in there .
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
PostPosted: 09:41 - 19 Aug 2012    Post subject: Reply with quote
Weird. Only thing I can think of (and unlikely I suspect) would be the thrust bearing failing and grabbing.
jimspeed
PostPosted: 09:48 - 19 Aug 2012    Post subject: Reply with quote
It does sound a bit rattley on idle but every kwak ive had does. It's definatly high load related hope it's not a gearbox problem or bearing etc
jimspeed
PostPosted: 11:18 - 19 Aug 2012    Post subject: Reply with quote
hmmm well got it all in bits and cannot find anything wrong apart from the plates being a bit dry (its been stood a while)
the basket bush seems ok and the thrust bearing has no play, Maybe its in the basket springs when they load up but I'm unable to find any movement there.
The last post was made 13 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 40.94 Kb
