de restricting a DT125r that doesent have a servo.
 Topic moved: from General Bike Chat to The Workshop by Bendy (14 May 2004 - 16:13)
dtmaster
PostPosted: 15:15 - 14 May 2004    Post subject: de restricting a DT125r that doesent have a servo. Reply with quote
basicly how is it done? i have been told its some little pin thing you pull out or something but i have no idea. On the newer model you do something with the servo for the powervalve but thats a the problem a 1993 deet doesent have one! any one got any ideas cos it only does bout 65ish and thats with a full big one re-jetted carb 240 and a pipercross!
cheers Ross Thumbs Up
1993 Yamaha DT125r
carvell
Scuttler
PostPosted: 15:45 - 14 May 2004    Post subject: Reply with quote
From what I've heard, there are some plates in the exhaust system that need to be removed.
If you're a bit good at welding you could cut open the exhaust and remove them, otherwise you'd need to buy a new exhaust.
Someone who knows more about DT's will no doubt post soon!
Yamaha TDM 850
Ninja
Caption Abuser
PostPosted: 16:33 - 14 May 2004    Post subject: Reply with quote
the powervalve will still be there, just without the servo to do the mving about - in that case all you need to do is wind the powervalve to the fully open position.
That should give max power at higher revs - but the transition of power from low revs to high revs is going to be like hitting an on/off switch - dangerous if it catches you unawares (going round a roundabout in the wet say)
James
4 wheels transport the Body ... 2 wheels transport the SOUL
dtmaster
PostPosted: 20:12 - 15 May 2004    Post subject: Reply with quote
so how do i go about doing this? i have already got a sports exhaust so theres no restrictors in that. is it something to do with the exhaust port? do i take the exhaust off?
cheers Ross
1993 Yamaha DT125r
Smoto Bob
PostPosted: 07:05 - 16 May 2004    Post subject: power valve, Reply with quote
Sooo need to right a FAQ about this lol
If you sit on the bike, look down on the left hand side of the barrel, theres a circular plate, that is where the valve hides under. Its pegged in position if you don't have the servo.
Remove the allan key bolts and have a gander, you should be able to pull the end out and now rotate the Powervalve, it will look like
It there for being held in by 2 flats on the bit you just pulled off. Its able to go in 4 positions. Only one is fully open. Ones closed, and the others are upside down Rolling Eyes
You suppost to re-jet the carb as well if you do this, especially if you have a non re-stricted exhaust.
Hold on when it get Very high up the revs as it will kick in harsh.
i take no responsibilty for anything ( ever Rolling Eyes )
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
The last post was made 21 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.26 - MySQL Queries: 16 - Page Size: 44.14 Kb
