RS125 vibrating LOADS please help!!
callum.s09
PostPosted: 17:10 - 12 Sep 2012    Post subject: RS125 vibrating LOADS please help!! Reply with quote
hiya guys i was riding home from college to day when my bike became a little bit sluggish and started to virbrate loads i mean my feet and legs were tingling i was thinking a bearing in the engine might be f****d but if you could help guys i reli appriate it.
THANKS CALLUM
dogwafter
PostPosted: 17:19 - 12 Sep 2012    Post subject: Re: RS125 vibrating LOADS please help!! Reply with quote
THANKS CALLUM
There isn't much to go on with what you have said, but for the sluggishness try a new plug (high performance 2 strokes eat plugs) Have you checked how tight the engine mounting bolts are?
andy_uk
PostPosted: 17:36 - 12 Sep 2012    Post subject: Reply with quote
The balance gears failing would cause the excessive vibrating. But like dogwafter said, it could be various other things causing this.
Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame...
callum.s09
PostPosted: 17:47 - 12 Sep 2012    Post subject: Reply with quote
Cheers guys well when its idleing its not vibrating bad but its worse at 5-6 thousand revs but still vibrates at higher revs, feels horrible, well il try new plugs and make sure everythink is secure.
thanks
Matt-
PostPosted: 18:34 - 12 Sep 2012    Post subject: Reply with quote
Get your wallet out, bottom end rebuild time Thumbs Up
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
callum.s09
PostPosted: 18:41 - 12 Sep 2012    Post subject: Reply with quote
ohh dear reli hope its not i was hopeing it wouldnt break down cos i wanna px it for a 600 soon Sad
andy_uk
PostPosted: 19:22 - 12 Sep 2012    Post subject: Reply with quote
Check the engine mounting bolts firstly.
I assume the vibration increases with the revs and not with the speed of the bike?
(i.e. is the vibration still apparent in neutral?)
If the bolts check out okay and the vibration is linked with revs and not speed then definitely check the balance gears and shaft. (not that difficult to do)
callum.s09
PostPosted: 19:55 - 12 Sep 2012    Post subject: Reply with quote
yes mate it vibrates with the revs when at a stop and when traveling it does also increase with the revs aswell., il check it all out tommorow. cheers anyway mate
Matt-
PostPosted: 20:46 - 12 Sep 2012    Post subject: Reply with quote
You will be very lucky if it's an engine mount, then engine would have to be falling out to make any sort of " Big " Vibration.
thomp1983
PostPosted: 21:44 - 12 Sep 2012    Post subject: Reply with quote
very unlikely it's an engine mount, there's 4 of them and i doubt you'd get much vibration with one undone. as has been said id be looking at the balance shaft gears and bearings, the gears are a service item and fairly easy to access, the bearings are an engine split job and will be costing £100+ in parts alone, as it'd be pointless just replacing the balance shaft bearings with the casings split
chris
andy_uk
PostPosted: 21:53 - 12 Sep 2012    Post subject: Reply with quote
If the balance bearing has gone, I'm pretty sure it can be replaced without splitting the case.
thomp1983
PostPosted: 16:26 - 13 Sep 2012    Post subject: Reply with quote
balance shaft has 2 bearings, front one just behind balance shaft gear with circlip should be replaceable with the engine in one piece, the rear one inside the gearbox isn't
chris
PostPosted: 00:06 - 14 Sep 2012    Post subject: Reply with quote
Engine mounts are easy to check. But balance shaft gears would be my first guess. They are service items. While the bearings might have gone I would order the gears and check the bearings while changing gears
andy_uk
PostPosted: 18:06 - 14 Sep 2012    Post subject: Reply with quote
chris
Yeah, I'd spent so much time with mine in bits I'd forgotten which bits were accessible from just taking the clutch cover off Wink
The last post was made 13 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 84.36 Kb
