Mod 2 - Do you put bike in Neutral at lights etc?
thepuma
PostPosted: 07:22 - 17 Sep 2012    Post subject: Mod 2 - Do you put bike in Neutral at lights etc? Reply with quote
As above.....I never ever put my bike in neutral when waiting at lights but read somewhere that its advisable to do it for your mod2. It's the first I've heard of this.....is it really necessary?
Has anyone received a minor for not doing it?
For me personally I find it too much faffing about coming to a stop, swapping legs to get into neutral, swapping back to hold the rear brake and then swapping legs again to change gear when the lights change whilst doing mirror,mirror shoulder check......
Anyone?
765 RS
weasley
PostPosted: 07:29 - 17 Sep 2012    Post subject: Reply with quote
If I know I'm going to be there for more than a few seconds then yes, I'll go into neutral. It eases the strain your hand and prevents the possibility of you accidentally dropping the clutch (or the cable snapping) and lurching forwards, potentially into danger.
The whole left-right-left foot dance is only for the test. In the real world most people just keep their right foot on the ground.
Pete.
PostPosted: 07:33 - 17 Sep 2012    Post subject: Reply with quote
Only if I want to rest my hands/wipe visor/adjust zip on my leathers or if I know they are a long interval. Mostly, I just wait in 1st with the clutch in.
a.k.a 'Geri'
Efes123
I never did for my test. But, I think it might be like filtering, some examiners expect it, others don't. You can ask the examiner before you start.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
thepuma
PostPosted: 07:35 - 17 Sep 2012    Post subject: Reply with quote
It just seems a bit like a faff..and imho can lead to other faults like not making progress, especially if you stop at lights and then as you're putting it in neutral the lights change, so you're floundering around dancing frantically left and right...potentially in the rush forgetting an obs and maybe stalling in the panic to get away in acceptable time.
765 RS
gaffa
PostPosted: 07:55 - 17 Sep 2012    Post subject: Reply with quote
I didn't do it for my MOD 2, was told by my ins to keep it in 1st. Suppose it is also 1 less thing to worry about while on test.
MOD 1 passed 30/07/12, MOD 2 passed 13/08/12. Current bike: 2008 Kawasaki ER6f
janner_10
The examiner doesn't give a flying fuck if your bike is in neutral of first at a junction and how is he going to know?
Leave it in first with the clutch in, saves you faffing about trying to get it in neutral.
Focus on the important stuff, like speed limits of the potential route or unusually tricky areas you could be riding in on the test.
Don't lose sleep over guff like this.
Good luck for the test though Thumbs Up Thumbs Up
Matt-
PostPosted: 08:53 - 17 Sep 2012    Post subject: Reply with quote
No i didn't.
But as for personal preference I do like taking my bike out of gear at the lights. Just easier.
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
doggone
PostPosted: 09:03 - 17 Sep 2012    Post subject: Reply with quote
He'd see you knock it into gear before setting off.
However I think it's only considered 'advice' for reasons already pointed out.
It's just the same with a non-auto car, not good for clutch or your foot sitting in gear for more than a minute or so.
Billo63
PostPosted: 09:31 - 17 Sep 2012    Post subject: Reply with quote
Plus if you go into neutral & then start looking at traffic flow, checking mirrors etc - all the things that you're trying to show examiner you are reading the road & then when time to pull away comes there's always a chance you forget that you ain't in 1st - (easy to go neutral but still keep clutch in!) you suddenly realise that everything behind you is been held up when way was clear, then that would at very least give examiner thoughts of totting up a minor - if not more serious.
Lights change frequently. junctions can clear instantly, it's just not worth it.
I might not be a gynecologist, but I know a cunt when I see one
map
Mr Calendar
PostPosted: 09:35 - 17 Sep 2012    Post subject: Re: Mod 2 - Do you put bike in Neutral at lights etc? Reply with quote
thepuma wrote:
Mod 2 - Do you put bike in Neutral at lights etc?.....I never ever put my bike in neutral when waiting at lights but read somewhere that its advisable to do it for your mod2. ...
For the test it's no. You do not have to go into neutral.
If you did then you'd have to make sure either front or back brake on all the time while stationary. See hendon shuffle in this thread.
Now seen as a little outdated, not required for the test and even advanced riding not specifically taught/required. However, it may be useful under some circumstances, like a hill start. Also as said if you're going to be waiting for some time. If you're on an older bike or want to care for the clutch then it's also an option. As said, avoid for the test though.
For test examiner is looking for control and correct use of the brake (via hand or foot) dependent on the circumstances.
HTH Thumbs Up
Matt B
PostPosted: 10:22 - 17 Sep 2012    Post subject: Reply with quote
You should leave it in 1st gear at the lights, that's the way it should be taught from CBT onwards.
As you approach the lights braking you drop into 1st just as you stop then the left foot goes down.
Right stays up on the rear brake and you can release the front.
Lights go red/amber you check mirrors and away bringing the right foot back up.
It's easier than swapping feet.
dungbug
PostPosted: 10:27 - 17 Sep 2012    Post subject: Reply with quote
I always put the bike in 1st at a stop regardless of how long I might have been there, left foot down, right on the brake. At least then you're ready to do your obs and pull away when ready, whens your Mod 2?
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Bomberman
PostPosted: 11:45 - 17 Sep 2012    Post subject: Reply with quote
I was told not to go into neutral for my test. Can't get away as quick if you need to, and just something else to get wrong I guess Smile
Flatbadger
PostPosted: 12:08 - 17 Sep 2012    Post subject: Reply with quote
I had my mod 2 a couple of weeks back, this didn't come up at all. I failed, but not because of that Wink
You're in ISIS
PostPosted: 12:26 - 17 Sep 2012    Post subject: Reply with quote
Agreed to all the above, I can't be arsed with doing a Hendon Shuffle that was designed for lanky legged Plod.
On a practical matter, I stay in gear to give myself a fighting chance of escaping a rear end shunt.
map
Mr Calendar
PostPosted: 12:35 - 17 Sep 2012    Post subject: Reply with quote
Rogerborg wrote:
...On a practical matter, I stay in gear to give myself a fighting chance of escaping a rear end shunt.
Do you also stay at least one bike length away* from the vehicle in front and at a slight angle to give you a getout route?
Confused
* I use about a bike and a half if I can. Like in a car you should be able to see the bottom of the bumper of the car in front over your bonnet (again I differ and prefer to see their tyres). This should give you enough room to manoeuvre around them if required.
Kradmelder
PostPosted: 12:44 - 17 Sep 2012    Post subject: Reply with quote
Confused
Im usually between the cages anyway. The only thing in front of me could be another bike.
I stop just bit ahead of the cage so they see me and dont clip me with their mirror or swerve in front of me, but if it is a nice looking woman with a low cut top I stop next to the cage door Mr. Green
I leave it in first for a quick getaway. But if I want to do the finger in hole hand sign then I need to put in neutral Mr. Green
Sometimes both feet down, sometimes one on rear brake.
2011 KTM 990 Dakar
2009 BMW 1200 GS
map
Mr Calendar
PostPosted: 13:09 - 17 Sep 2012    Post subject: Reply with quote
Kradmelder wrote:
...if I want to do the finger in hole hand sign then I need to put in neutral Mr. Green ...
Typical SA greeting then, I learn more about your culture with every post Wink Very Happy
Alpha-9
PostPosted: 13:17 - 17 Sep 2012    Post subject: Reply with quote
Same as others, I only neutral if I know its a set of lights which is a PITA
and thats only so I can drum and ping my tank out of boredom
Today I accidentally clutched a wheely on my YBR, while pulling off the line between two cars, people were staring like I meant to do it...I wasn't aware it was even possible
Gonna try again later Thumbs Up
Fzr-600 1999
Kradmelder
PostPosted: 13:40 - 17 Sep 2012    Post subject: Reply with quote
well i tried tipping my hat at the ladies, but my lid is firmly strapped under my chin, they cannot see my tongue hanging out, so only the hands are left to show gentlemanlike behaviour Mr. Green
2011 KTM 990 Dakar
2009 BMW 1200 GS
Ribenapigeon
PostPosted: 14:33 - 17 Sep 2012    Post subject: Reply with quote
I never used to select nuetral at junctions or in quing traffic but now i do if im waiting on lights or quing its good practice. I can do it now with feeling like im hopping about, i just have the bike ballnced and slipp it in and out of nuetral as easy as pie. I did wonder the same though about during MOD2.
Bomberman
PostPosted: 15:32 - 17 Sep 2012    Post subject: Reply with quote
Boozehawk wrote:
its good practice.
What makes you say that though? Like I say, I was told it's a bad idea - if you need to get away quick, you've got to get back into gear first.
Teflon-Mike
tl;dr
PostPosted: 16:39 - 17 Sep 2012    Post subject: Reply with quote
You wont fail for not using neutral & holding it clutch in on test.
You might for attempting to do it 'By the book' and fucking it up!
By the book is something known as the "Cardington Clog Dance" or 'The Met Shuffle"
Saftey Possition? Remember that from CBT? Left foot down propping bike up, right foot up covering, but not necesserily applying rear brake, unless on a hill.
Slowing for the junction, you aporoach in 2nd gear, and clutch in JUST as you stop.... assume Safety Pos.
Now CCD/MS...
Reverse foot, covering front brake with right hand, Right foot down, left foot up, select Neutral, re-assume Safety possition, reverse footing again, left foot down, right foot up to cover brake.
You are now preparing to pull away....
Cover front brake, with right hand, reverse foot, right foot down to prop bike, left foot up to select 1st gear, reverse foot again, left foot down to prop bike, right foot up to cover brake, hand off the front brake....
And OH shit, the gap you were going for has gone....... back to neutral.. try again!
You'd be there for ever like a cat on a hot tin roof changing footing never moving!
CAN be done.... and there are riders, usually police riders, instructors or examiners to whome its so 'drilled' and they have such precission & smoothness that they CAN do it and do it so intuitively and swiftly that it doesn't hold them up.... but for mere mortals? Something that takes a LOT of practice and NOT expected of a two year newb!
For you?
Draw up to stop in 2nd, DONT risk a learner-lurch changing to 1st and getting excessive engine braking just before the stop, OR risk examiner spotting you snick first but hold it clutch in 'coasting' to the halt.
Roll to the line in 2nd, Using rear brake. assume safety possition, reverse foot straight away, find first...... reverse foot, back into safety possition, keep the clutch 'in' till you are ready to launch.
It is NOT, repeat NOT 'best form'. But iot works.
Its not good form, becouse it keeps tension on your clutch sprrings and clutch cable excessively, which means they will wear out faster.
But its the safety implication thats more critical. IF your clutch cable snaps while you are holding it in, OR your grip of the lever is relaxed for any reason; knock from a pedestrian weaving through stationary traffic crossing the road, car wing mirror from car forcing an extra lane, or you are other wise knocked distracted or just sneaze..... bike will launch... it wont 'fail-safe'.
IF its obviouse its going to be a long wait... worth using neutral. Cardington-Clog or Met-Shuffle may be a bit of a faff, but when you are on a bigger bike, with more 'oomph' to make getting intoi gaps easier.... using Neutral if not the full polava of teh Cardington-Clog can be useful..... if for no other reason than hanging onto the much heavier clutch of a big-bike can have your wrists and fingers aching like bludgery after a couple of hours of such stop start riding!
Ribenapigeon
PostPosted: 17:07 - 17 Sep 2012    Post subject: Reply with quote
Bomberman, I say good practice meaning practicing keeping balance while dancing from ground to pegs not as in its good technique to always go into neutral. There are rarely sitiuations where you have to be rapid off the mark though, especially at lights or queing. Also there are some places where it is positivly safer when you have to wait to be in nuetral, I'm thinking when turning across oncoming traffic mostly and especially when in the middle of dual carriagway.
I also notice more experienced riders doing it a lot and it looks smooth when they do and to my mind being smooth is always good as far as riding is concerned. Its good to practice feeling your way into neutral with your toe as well. Its all more control which again is always good.
The last post was made 13 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.3 - MySQL Queries: 13 - Page Size: 140.47 Kb
