| _mjs_ |
 _mjs_ Could Be A Chat Bot
 Posted: 20:21 - 30 Aug 2012 Post subject: Snapped CB 500 exhaust stud - What do? |
Hi all,
I noticed my bike was a bit louder than normal the other day so I checked it out when I got home.
It turned out one of the exhaust pipes was missing a bolt and blowing exhaust fumes out of the head.
I ordered some replacement copper gaskets and when they turned up today I whipped the downpipes off and found the stud had sheared off. Gave it a blast of WD and a quick rive about with some mole grips but it wasn't budging.
Rather than make it worse I reattached me pipes and this seems to have got a good seal, the bike's running great now... but I'm guessing it'd fail an MOT with only three bolts instead of four?
I've ordered replacement studs but I'm wondering if there's a tool of some sort that will get the broken bit of stud out? Thanks in advance for any advice and I'll attach a picture of what I'm dealing with
-Mark ____________________ Previous Bikes: 2006 Honda XR125L > 2003 Yamaha DT125R > 1996 Honda CB500
Current bikes: 1997 Kawasaki ZZR 600 E5 > 2006 Honda Varadero XL125V |
| neatbik |
 neatbik World Chat Champion
 Posted: 20:29 - 30 Aug 2012 Post subject: |
You can get stud extractors -
https://www-1.toolbox.co.uk/draper-58710-10mm-stud-extractor-part-00087936M.jpg
They generally work quite well.
Methods to remove stuck studs - (in no particular order)
Heat, and then mole grips.
File 2 flats on it.
Weld a bar on the to turn it with.
Stud extractors (as shown in above pic)
Finally if nothing else works then cut it off flush and drill it out. |
| _mjs_ |
 Posted: 21:02 - 30 Aug 2012 Post subject: |
Cheers I'll order one of those and a blowtorch Really don't fancy taking a drill to my engine! ____________________ Previous Bikes: 2006 Honda XR125L > 2003 Yamaha DT125R > 1996 Honda CB500
| neatbik |
 Posted: 21:09 - 30 Aug 2012 Post subject: |
| stonesie |
 stonesie World Chat Champion
| thomp1983 |
 thomp1983 Crazy Courier
| GREENI3 |
 GREENI3 World Chat Champion
 Posted: 21:53 - 30 Aug 2012 Post subject: |
The downpipes on my cb look like they're pretty much welded to the engine, theres that much rust.
I'll be investing in a full stainless motad system after winter.
Think I'd rather leave it to the local garage to fit that though. |
| _mjs_ |
| _mjs_ |
| Bezzer |
 Bezzer World Chat Champion
 Posted: 22:45 - 30 Aug 2012 Post subject: |
I've got one of those and don't rate them much for M8 and under studs, when you stick a ratchet on them it's off centre to whatever you're trying to remove and can snap them pretty easily. The ones in a set are much better as the ratchet is in line with the stud, got a set of those from Machine Mart. ____________________ I used to be indecisive but now I'm not quite so sure. |
| Rogerborg |
 Rogerborg nimbA
| bikenut |
 bikenut World Chat Champion
| neatbik |
 Posted: 11:55 - 01 Sep 2012 Post subject: |
| Bezzer wrote: |
I've got one of those and don't rate them much for M8 and under studs, when you stick a ratchet on them it's off centre to whatever you're trying to remove and can snap them pretty easily. The ones in a set are much better as the ratchet is in line with the stud, got a set of those from Machine Mart. |
Cheers, i suspected they might not be much use, but having never used them i obviously couldn't say for sure.
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| Thunderlips |
 Thunderlips Derestricted Danger
 Posted: 20:27 - 29 Sep 2012 Post subject: |
You lot are great, i have pretty much the same on my CBR600F.
I assume it is a very good idea to remove the petrol tank before i go to town with the blowtorch on the stud , also how long(hot)should i get the stud?
Any advice very appreciated as i am hopeless at this sort of stuff(hence snapped stud to begin with)
Thanks |
| temeluchus |
The last post was made 13 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
