MZ update
mic
PostPosted: 06:34 - 24 Oct 2012    Post subject: MZ update Reply with quote
MZ ended up in a garage.... new clutch plates - 5 old ones, some were broke some were cracked - replaced with 6 new ones that came in a pack, no explination why there was only 5 before.
Kickstart mechanism teeth part completely shagged + mating cog, so all replaced.
Ride home was about 45 mins, cut out 2 mins round the corner. Cant remember exactly what i did to get it started again but its a fuel blockage - unplug the fuel line and nothing drips out.
Kicked it up this morning at 5am ish and it fired up no problems but cut out again round the corner! Again, no petrol coming out of the fuel line. I assumed it was a build up of crap in the tank and unscrew the petrol cap - fuel line thats still disconnected starts pissing petrol!! Fired up and got to work.
I assume there is an air filter somewhere for the fuel tank that is blocked. Would that sound about right?!
zzr600
temeluchus
PostPosted: 06:55 - 24 Oct 2012    Post subject: Reply with quote
Should be a breather somewhere, either in the cap or around the tank somewhere. make sure its clear.
bikenut
PostPosted: 11:34 - 24 Oct 2012    Post subject: Reply with quote
Very Happy could be vent in cap, check whilst flushing tank and tap, flow test afterwards ( gallon in 5 mins??).
if filter u/s, try small vw type.
some pics and 5 speed model?? Very Happy
mic
PostPosted: 11:40 - 24 Oct 2012    Post subject: Reply with quote
Will have a look in a minute and take a few pics.
Only use 5th gear if I wanna go slower LOL
zzr600
mic
PostPosted: 12:32 - 24 Oct 2012    Post subject: Reply with quote
Pictures here https://www.bikechatforums.com/viewtopic.php?p=3371932#3371932
zzr600
map
Mr Calendar
PostPosted: 12:44 - 24 Oct 2012    Post subject: Reply with quote
Quick question(s)
Do you use pre-mix, as in get a can of petrol, put right mix of oil in that and then fill bike tank?
Or are you trusting the oil pump doesn't fail?
Otherwise I think these are good bikes providing they can be maintained. Would have had one myself when I started if I hadn't been offered a CG at a bargain price.
mic
PostPosted: 12:49 - 24 Oct 2012    Post subject: Reply with quote
So far I'm using the reservoir and the pump seems to be ok, you can see the level dropping. On the inside of the fuel cap is a little tub which you can measure and add oil with so should be ok I'd the pumps starts to fail
zzr600
PostPosted: 13:07 - 24 Oct 2012    Post subject: Reply with quote
There is a pinhole in the middle of the filler cap to allow air to get back into the tank as fuel runs out.
Stick a straightened paperclip in the hole, wiggle it about then blow down it. If air comes out the other side, you have successfully fixed the problem.
Most MZ servicing goes something along these lines.
temeluchus
PostPosted: 20:13 - 24 Oct 2012    Post subject: Reply with quote
Or putting threadlock on the gearchange pinch bolt after searching the hedge for the damn thing the third time its slacked off and the lever disappeared.
The last post was made 14 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 14 - Page Size: 61.34 Kb
