NOS setup.
Jack2004
PostPosted: 23:46 - 21 May 2004    Post subject: NOS setup. Reply with quote
Just a picture to show how NOS is setup.
kev
I Hump Things
PostPosted: 07:38 - 22 May 2004    Post subject: Reply with quote
Pipeing it in is easy, its the wiring which is a pain.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Valentino Mossy
PostPosted: 21:03 - 22 May 2004    Post subject: Reply with quote
Call me stupid but, Why do you need the electric pump for the fuel ?
Or does it need more ummph to get it into the carb ?
kev
I Hump Things
PostPosted: 21:04 - 22 May 2004    Post subject: Reply with quote
As the combuston happens allot quicker the carb cannot cope with the sudden increase so you have to add more fuel or the bike will run very lean and then blow up.
Valentino Mossy
PostPosted: 21:10 - 22 May 2004    Post subject: Reply with quote
Going by the diagram, your using the normal way of putting fuel into the carb via the tank AND Adding more fuel via the electric pump to the nos into the air pipe thing in front of the carb ?
Well you learn something new everyday ! Thanks Thumbs Up
Now all i need to find out now is where babies come from Confused
kev
I Hump Things
PostPosted: 21:12 - 22 May 2004    Post subject: Reply with quote
Wish I knew the answer to that one, well hopefully I will know in about 6 weeks. Very Happy
loply
PostPosted: 20:52 - 23 May 2004    Post subject: Reply with quote
Nitrous systems usually use an "Enrichment Fuel Injector" to compensate for the fact that the carbs or EFI wasnt designed for the density of O2 the nitrous contains.
The last post was made 21 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 50.26 Kb
