How to drill out a broken stud.
Pete.
PostPosted: 22:41 - 26 Nov 2012    Post subject: How to drill out a broken stud. Reply with quote
Here is how I tackling the 8 broken studs on my 1996 Bandit. Forget easy-outs and stud extractors for frozen-in bolts, you will veru likely only make things much worse.
There are a couple of tried and trusted ways to remove a stud that has some thread showing.
One way is to put a nut over the stud and weld the end with a mig welder getting it nice and hot, then un-doing the nut which should bring the stud with it. I don't have a mig welder - I have an arc welder but they are much harder to get good results with since the rod is fatter and for small diameter studs it's likely the arc will wander when you try to weld in the well of the nut.
The other way is to drill out the stud. This is no easy task, starting off on the end of a sheared stud is tricky and you must be dead centre to avoid having the drill wander off the bolt into the softer ally threads. This is how I have done it - by making a drill bushing.
First, take an old 12.5mm drill and chuck it up in the lathe backwards. Drill bits are not hardened at the shank so you can drill, file and cut them but they are made from hardenable steel which is what we want. Drill the tail-end 6.8-7mm which is tapping size for a M8 bolt.
https://peterrimmer.myby.co.uk/images/drillstud1.jpg
Then drill it deeper with a 4mm drill, which will be the pilot for drilling out the stud.
https://peterrimmer.myby.co.uk/images/drillstud2.jpg
Now I set up a M8 taper tap in the lathe using the centre to keep it perfectly in line.
https://peterrimmer.myby.co.uk/images/drillstud3.jpg
And follow it with a 2nd tap and plug tap to get the thread right to the bottom of the hole.
https://peterrimmer.myby.co.uk/images/drillstud4.jpg
https://peterrimmer.myby.co.uk/images/drillstud5.jpg
After that I part it off.
https://peterrimmer.myby.co.uk/images/drillstud6.jpg
Now I need to be avble to tighten this bushing, so I file two flats in it for a 10mm spanner.
https://peterrimmer.myby.co.uk/images/drillstud7.jpg
https://peterrimmer.myby.co.uk/images/drillstud8.jpg
Broken studs.
https://peterrimmer.myby.co.uk/images/drillstud9.jpg
Bushing fitted
https://peterrimmer.myby.co.uk/images/drillstud10.jpg
I used the drill rod so I could harden the bushing for use. This involves heating it up to cherry red and quenching. Here is what I did, but unfortunately I could not get it hot enough on my gas ring to lose it's magnetism (which is when it becomes hardenable) so it remained soft - so I used it anyway. Tomorrow I will take it to work and heat it with oxy-acetylene then it will be glass-hard.
https://peterrimmer.myby.co.uk/images/drillstud11.jpg
https://peterrimmer.myby.co.uk/images/drillstud12.jpg
As you see, the drill now takes a straight path directly dwn the middle of the stud.
https://peterrimmer.myby.co.uk/images/drillstud13.jpg
Drill extension for those hard-to-reach ones. Just a bit of mild steel rod, grind four small flats on the drill you use to drill the rod with then poke it in and give it a little squeeze in the vice.
https://peterrimmer.myby.co.uk/images/drillstud14.jpg
Holes drilled, spot on - only 6 more to go.
https://peterrimmer.myby.co.uk/images/drillstud15.jpg
a.k.a 'Geri'
neatbik
PostPosted: 22:48 - 26 Nov 2012    Post subject: Reply with quote
Awesome.
Cheers Pete, i will remember that one.
Karma Thumbs Up
stonesie
PostPosted: 23:00 - 26 Nov 2012    Post subject: Reply with quote
This makes me want a lathe, badly.
Top work Thumbs Up
binge
Emo Kiddy
PostPosted: 23:41 - 26 Nov 2012    Post subject: Reply with quote
Where is the Awesome rating when you need it!?! Thumbs Up
Nice one Pete! I might need to bell you up about tapping soon. I need to tap 8 holes to M10x1.5, but ideally need the thread to go all the way to the back of the hole.
Ben
Pete.
PostPosted: 00:26 - 27 Nov 2012    Post subject: Reply with quote
Ben
No worries - I have a M10 plug tap.
a.k.a 'Geri'
grahamd1
PostPosted: 09:30 - 27 Nov 2012    Post subject: Reply with quote
Fantastic, now for us mere mortals without a lathe,
HOW MUCH MISTER ?
Gotta have one
XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild),
nowhere.elysium
The Pork Lord
PostPosted: 10:23 - 27 Nov 2012    Post subject: Reply with quote
That's a clever workaround. Nice documentation of the process Pete. Thanks for sharing it Thumbs Up
kestrel
PostPosted: 21:27 - 27 Nov 2012    Post subject: Reply with quote
Nice well written post Pete. A set of these drill guides manufactured from a suitable material and induction hardened would be a useful addition to anyone's toolbox.
Perhaps you should contact a certain BCF member who has recently acquired a brand new CNC machine. Wink
Isle of Man.........Road Racing Capital Of The World
kramdra
PostPosted: 21:36 - 27 Nov 2012    Post subject: Reply with quote
This is good. I tryed mig welding mine, no good.
my CBR6 snapped 7 bloody studs. I found a local machinist and asked him to make me up one of these, he said it wouldnt work and id be ok doing it freehanded. So I invested in some TiN coated drills and carbide burrs (awesome). I tryed and buggered the first stud.
Decided to let shop do it, cost £800 included removing head, drilling out on machine and welding the buggered hole and putting it all back.
TomGT
I'd buy one, as would most of BCF I imagine Thumbs Up
1992 ZXR 400
PostPosted: 21:37 - 27 Nov 2012    Post subject: Reply with quote
Easier option.
Sell. Laughing
kestrel
PostPosted: 21:39 - 27 Nov 2012    Post subject: Reply with quote
##Paddy## wrote:
Easier option.
Sell. Laughing
Welcome back ##Paddy## Laughing
PostPosted: 21:40 - 27 Nov 2012    Post subject: Reply with quote
Thanks Thumbs Up
Great write up Pete
Pete.
PostPosted: 22:19 - 27 Nov 2012    Post subject: Reply with quote
Diod some more tonight. 6.5mm drill down the middle:
https://peterrimmer.myby.co.uk/images/drillstud16.jpg
https://peterrimmer.myby.co.uk/images/drillstud20.jpg
Too small as it leaves the thread intact, though it looks pretty cool. Tapping size is 6.8 but I wanted to allow a bit of extra clearance so I went for a 7mm drill. Tapped using a 1/4" socket extension backwards in the tap wrench to reach past the frame. You need a GOOD tap to do these:
https://peterrimmer.myby.co.uk/images/drillstud17.jpg
https://peterrimmer.myby.co.uk/images/drillstud18.jpg
Both done and bolts fitted:
https://peterrimmer.myby.co.uk/images/drillstud19.jpg
https://peterrimmer.myby.co.uk/images/drillstud21.jpg
Middle ones will have to wait until I get some more 4mm drills Smile
a.k.a 'Geri'
Raffles
PostPosted: 23:08 - 27 Nov 2012    Post subject: Reply with quote
Will you be re-installing socket cap screws?
Pete.
PostPosted: 23:16 - 27 Nov 2012    Post subject: Reply with quote
Yes, I'll be doing that. 16 years of rot hasfrozen them in and embrittled the bolts, I doubt the bike will be around in another 16.
a.k.a 'Geri'
Walloper
PostPosted: 08:17 - 28 Nov 2012    Post subject: Reply with quote
Good idea and a good example to all BCFers on how to take a bloody photograph for illustration purposes. Laughing
A Tip for drilling Exhaust Studs.
They can get hardened form heat/cold cycling and normal bits don't last long when drilling.
I got this idea from an Engineer friend many hoons ago.
Take a masonry bit.
Grind a 'cutting' angle on the top of the tungsten carbide insert. (They are flat or rounded from the factory as they do not cut but impact and mash masonry)
They are very able to take massive abuse in service so are almost indestructible.
When sharpened they whiz through the hardest steel like a hot knife through butter.
If there is concern that the tip will wander then grind the wee bits of 'clearance' off the sides to the same diameter as the shank.
And lubricate.
The last post was made 13 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 108.71 Kb
