| Bikermice |
 Bikermice Nova Slayer
| Aff |
 Aff World Chat Champion
 Posted: 15:17 - 04 Dec 2012 Post subject: |
Ah is how long the battery will last on a single charge, not how much power it can output. You will need to match the batter to the CCA (Cold Cranking Amps) of your bike.
On a 125 a 4 or 6Ah will be fine.
Just make sure you get one that's the right size.  ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project
| J.M. |
 J.M. World Chat Champion
| stinkwheel |
 Posted: 15:21 - 04 Dec 2012 Post subject: |
Buy the correct one for your bike.
ie, the same shape, size, voltage, amp hour rating and terminal layout as the one it came out of the factory with.
Hopefully, this is the same as the one that's in it.
Once you've found it, the more you spend, the better the quality of the battery. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| monkeymark |
 monkeymark Borekit Bruiser
| stinkwheel |
 Posted: 15:32 - 04 Dec 2012 Post subject: |
The size of battery required depends on:
* The charging output of your alternator.
* The power requirement of the electrical systems.
* The size of the engine (and therefore the current the battery requires to turn the starter motor).
* The physical space available.
Put a large battery on a bike with a low charging output and you'll never get it fully charged. The alternator will be running constantly trying to do so and could eventually burn out, as well as putting a lot of load on your engine.
Put a small battery on a bike with a high power requirement and you'll keep deeply discharging the battery. It wont last very long.
So. The correct size depends on the bike and the manufacturer has usually worked this out for you. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alpha-9 |
 Alpha-9 Super Spammer
| Bikermice |
| monkeymark |
| johnsmith222 |
 johnsmith222 World Chat Champion
 Posted: 16:40 - 04 Dec 2012 Post subject: |
No real reason not to get a motobatt battery nowadays. I've got one for my ZX9R and you can really see the high standard it has been built to. I have not had it long enough to know how reliable it is. It's 6 months old.
Although I do know I cranked the bike over no problem after it was sitting up for 2 weeks (with a horrible datatool alarm draining on it).
I have read that they replace it within a year if it dies. I've read someone getting a replacement for their hayabusa and they honoured it.
The problem in that case wasn't actually the battery though, it was the guys charging system.  |
| TomGT |
 TomGT Spanner Monkey
 Posted: 19:46 - 04 Dec 2012 Post subject: |
I put a motobatt into the CBR earlier today, starter kicks over twice as fast
Chuffed  ____________________ 1992 ZXR 400 |
| LordShaftesbu... |
 LordShaftesbu... World Chat Champion
| Shinigami |
 Shinigami World Chat Champion
| sickpup |
 sickpup Old Timer
| Bikermice |
| Alpha-9 |
| stinkwheel |
The last post was made 13 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
