Heated grips - what glue?
james1988
PostPosted: 10:59 - 26 Dec 2012    Post subject: Heated grips - what glue? Reply with quote
Hello,
This may be a really stupid question however, what glue would you recommend for use with heated grips? My other half bought me a pair of the Dayton grips for Christmas and I intend on fitting them today.
I was thinking of using Araldite as it's ridiculously strong or is there a specific type of glue out there that will allow you to remove the grip without to much fuss but is strong enough for normal day to day use? I'm more than likely over thinking this... Laughing
James
Skudd
PostPosted: 11:06 - 26 Dec 2012    Post subject: Reply with quote
Does it not come with glue? Most kits that I know of do with the glue acting as lube to get the things on with.
james1988
PostPosted: 11:11 - 26 Dec 2012    Post subject: Reply with quote
Unfortunately not. It suggests something like Araldite on the back of the packaging as it reads "Must use an exclusive glue for grips or a glue of mixing two chemicals when inserted to a handle bar".
Hobgoblin
PostPosted: 11:16 - 26 Dec 2012    Post subject: Reply with quote
I was suggested Evostik impact adhesive, worked for my normal grips too so I dont see why it work wont for heated?
Plodding along on my CG
orac
PostPosted: 11:41 - 26 Dec 2012    Post subject: Reply with quote
do want to be able to take them off at some point??
my normal grips are held on with some spray paint, spray some onto the tube, slide grip on while wet and allow to dry. remeber while its gold it take paint a long time to dry in cool, wet climate
james1988
PostPosted: 11:43 - 26 Dec 2012    Post subject: Reply with quote
I'm happy leaving them on there and not taking them off. If I ever sell the bike, I'll sell them with it.
Hobgoblin, I'll have a look in to that. Cheers. Karma
orac
PostPosted: 11:48 - 26 Dec 2012    Post subject: Reply with quote
impact adhesive it is then
PostPosted: 12:36 - 26 Dec 2012    Post subject: Reply with quote
Most sets I have seen have just come with a tube of a cheap superglue. And I have used superglue on them a fair few times with no problems (beyond needing to be quick to put them on - having them stuck on half way along the bars is a tad inconvenient)
Easter Bunny
PostPosted: 12:41 - 26 Dec 2012    Post subject: Reply with quote
Firstly This is not a joke. someone told me to use a dab fairy liquid, not a lot at all just a dab enough to smear over the grip area, the fairy dries over night to a tacky substance which grips solid however quite easy to remove the grips by sliding a flat screwdriver around.
This was suggested when it took a couple of hours to remove my last ones when they stopped working, try it and see..........you can always remove it easy and glue it within an inch of its life if you're not happy
PostPosted: 12:44 - 26 Dec 2012    Post subject: Reply with quote
Hair spray is the normal suggestion for this.
cimbian
PostPosted: 13:06 - 26 Dec 2012    Post subject: Reply with quote
IPA (alcohol). Cleans old crap, acts as a lub and evaporates leaving high friction bond.
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
james1988
PostPosted: 15:48 - 26 Dec 2012    Post subject: Reply with quote
Thanks all, I'll give the hairspray a go first.
James
Nick_Giles
PostPosted: 17:03 - 26 Dec 2012    Post subject: Reply with quote
Spiral wrap the handlebar with double sided tape and remove the backing.
'Swish' the inside of the grip with petrol and quickly push onto the bar. - Petrol evaporates quite quickly leaving them well and truly stuck.
If you ever need to get them off inject petrol with a syringe between grip and bar and pull off. Smile
Nick
johnsmith222
PostPosted: 17:48 - 26 Dec 2012    Post subject: Reply with quote
James
Don't bother doing this.
I did this with the same grips, as well as lockwiring them on in 3 places (both ends and the middle) and also having a bar end on top of the rubber bit on the clutch side.
The grip turns relatively freely after a few weeks.
I'd maybe try araldite or spraypaint as has been suggested.
Valentino Mossy
PostPosted: 18:51 - 26 Dec 2012    Post subject: Reply with quote
Renthal do sell the glue for a couple of £, i had shit with my heated grips so used that. Just make sure you put the stuff on and leave it set for a day to make sure the grips dont slip.
johnsmith222
PostPosted: 18:58 - 26 Dec 2012    Post subject: Reply with quote
I've got the renthal glue and it worked great with my renthal medium grips on my 9R and they are solid. I lockwired both ends also.
This was not the case for these daytona heated grips. The renthal grips seem to be made of a softer compound and they fit the bars relatively tightly. These daytona grips seem to be much harder and slide on and off very freely. I glued the daytona grips with renthal grip glue but it failed fairly rapidly.
Pockets
PostPosted: 02:40 - 29 Dec 2012    Post subject: Reply with quote
Honda do a special grip glue, I got a tube from David Silver Spares.
crackfinder
PostPosted: 16:05 - 30 Dec 2012    Post subject: Reply with quote
bluezedd wrote:
James
I used hairspray to fit my replacement grips last year, worked a treat, slid them on easily and got them positioned correctly, then left them over night, they haven't budged since...solid as a rock they are, I did use the daughters superhold hairspray tho so that may have helped Thumbs Up Very Happy
Yamaha FZS600 Fazer (gone but not forgotten). Current - Kawasaki ZX6R A1P
GrumpyGuts
PostPosted: 16:13 - 30 Dec 2012    Post subject: Reply with quote
Can you use Vodka to clean and create an adhesive when replacing the grips?
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
SpeakForYou
PostPosted: 03:15 - 03 Jan 2013    Post subject: Reply with quote
I bought my R&G heated grips off ebay and they came with a tube of this: https://www.ebay.co.uk/itm/Motorcycle-handle-bar-grip-glue-road-race-grips-adhesive-ideal-Ducati-or-Aprilia-/150874684073?lgeo=1&clk_rvr_id=434170914587&vectorid=229508
Works great on mine.
CarlosCBR
PostPosted: 07:53 - 03 Jan 2013    Post subject: Reply with quote
I've never had an issue with using hairspray. Takes me back to m BMX days Very Happy
johnsmith222
PostPosted: 09:34 - 03 Jan 2013    Post subject: Reply with quote
Suspect its to do with these grips not fitting as tight as other normal grips and seem to be a hard rubber.
Perhaps water doesn't help things either if riding in all weathers.
YBR Ric
PostPosted: 10:57 - 03 Jan 2013    Post subject: Reply with quote
I've always used hair spray ands never suffered with grip slippage - Because my bike's worth it!
There is a gap of 7 years, 275 days between these two posts...
RodRides This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
NJD
PostPosted: 16:52 - 03 Oct 2020    Post subject: Re: Heat Grip Installation Reply with quote
RodRides wrote:
It is important to wire your heated grip from an ignition source and not direct to the battery, here is how to remove & install grips and wire.
Cheers for that Sir Spam-o-lot.
I'm sure after eight years of waiting your link is incredibly helpful to the OP.
Also while there is an element of personal preference some heated grips come with this brilliant thing called a in-line fuse. Thumbs Up
The last post was made 5 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 127.99 Kb
