| clemsta |
 clemsta Scooby Slapper
 Posted: 17:24 - 31 May 2004 Post subject: Jetting a NS125R for a Arrows Pipe |
I'm about to de-restrict my bike, i have been able to get a cheap second hand arrows system, i have been told that i need to re-jet the bike, what size of jet should i use, how many jets are there that need to be replaced, can i buy a kit and if so where from and how much.
Thanks for your help.  |
| hollamat |
 hollamat Two Stroke Sniffer
 Posted: 20:45 - 31 May 2004 Post subject: jets? |
try www.dellorto.com main jets are £2.95 each.
They may also be able to give you advice on jets sizes! |
| clemsta |
| bikedudextrm |
 bikedudextrm Traffic Copper
 Posted: 04:13 - 01 Jun 2004 Post subject: |
Just see what size main jet is in your bike at the moment, fit the exhaust and up jet a couple sizes, see how it runs and check the condition of the plug and up jet more if necessary until it's runs correct. ____________________
https://www.bikepics.com/members/bikedudextrm/ |
| clemsta |
 Posted: 13:57 - 01 Jun 2004 Post subject: |
Thanks for the info, i've been told that the standard jet size is 110, is it just the main jet that you change, has anyone done what i am about to do?
What did you do?  |
| ts50x0 |
 ts50x0 Spanner Monkey
 Posted: 17:25 - 07 Jun 2004 Post subject: |
i havre not done an nsr but on my 50 when i put on a racing exhaust i put one in that was one size bigger. that is just the ,mamin jet and it was perfect so just up the main jet size by a bit and check the plug each time. in the haynes manuals they show you what to look for in a plug and if its runing too hot, cold ect......
hope that helps  |
| clemsta |
| nsr125sp |
 nsr125sp Renault 5 Driver
 Posted: 00:11 - 08 Jun 2004 Post subject: re |
Hello i have just fitted a new arrow system to my nsr, the standard jet size is 135 and believe it or not i had to lean it off as it was too rich, i have gone down to a 130 in stages which has made it better, aprrently on some high performance 2 strokes this is needed to get the max performance, check the plug also !!
ollie ____________________ Nsr 125, Vfr 400
https://www.bikepics.com/members/nsr125sp/ |
The last post was made 22 years, 127 days ago. Instead of replying here, would creating a new thread be more useful? |
