| MillaMeter |
 MillaMeter Nova Slayer
 Posted: 11:30 - 25 Jan 2013 Post subject: My Egay Bargain Project |
Hi,
Just recently picked up this old girl with a spare engine and odds and sods from London for just shy of 300 squid.
She's a 1984 Kawasaki ER250 B1 Scorpion Belt Drive.
https://img404.imageshack.us/img404/9504/201301170442.jpgAccording to howmanyleft there is only 8 B1s in the uk
Anyway...
Bike is in very clean complete condition. Frame had been powder coated, engine casings, wheels, hangers etc.. blah blah blah
The bike was cheap for a reason though.
The engine doesn't run.
Seller said suspected crankshaft gear stripped. He also said that when he tries to turn the engine by hand (on the crank with a ratchet) the engine turns a few times then stops. But the engine turns backwards fine, hmmmmm... sounds like timing to me.
So out came the spanners, tea and fags and got cracking.
First of all I thought I'd have a dig at the cam chain tensioner. All necessary parts were removed to gain access. I was shocked when I managed to undo both tensioner body bolts with my fingers
Turns out the tensioner had been reset... but not released once in the engine. The seller also mentioned to me when collecting the bike that he had replaced and fitted the tensioner internals with brand new genuine kawasaki parts.
Looks like he forgot to release the tensioner
Because the tensioner wasn't released, I thought I'll just double check that it has been assembled correctly. Turns out it hasn't, the washer that goes on the rod before the spring, was infact after the spring thus causing this:
https://imageshack.us/a/img820/2161/201301210469.jpg
https://imageshack.us/a/img715/9359/201301210472.jpg
The washer I had to dig out with a small flat blade. Guess that's bolloxed then
Luckily the seller gave me a spare engine and parts with the sale as the spare engine had a good tensioner and that small washer intact
The tensioner is now rebuilt correctly and is ready and waiting to go back in the engine.
Next was to check the valves, timing and cam.
After ~10 min of wrenching, I managed to set the engine to TDC without jamming it up. Then with much swearing and spanner throwing I lifted the valve cover off. Much to my surprise I instantly saw the problem. Looking at the cam sprocket the 2 lines that are supposed to line up with the valve cover surface wasn't there.
But here, positioned 6 teeth backwards.
https://imageshack.us/a/img545/1258/201301210473.jpg
Next I'll check the valve cover for wear on the rockers.
It turns out that 1 of the rockers has been overtightened causing apart of the rocker to turn blue in colour and get eaten from the cam lobe.
https://imageshack.us/a/img547/2442/201301240492.jpg
3 used rockers from Egay on order and waiting to be delivered.
Moving on...
Going by what I have read on the net, these engines are almost identical to the GPZ305. Research on this bike didn't look good for me. Alot of things go wrong with these bikes and I'm now starting to think I'm going to get the same treatment with this ER.
1. was to check the oil pump gauze??
So oil pump off and oil pump gauze out:
https://imageshack.us/a/img197/6531/201301240487.jpg
Seems to be a lot of metal build up on the mesh. I'm guessing from the rocker maybe?
Managed to clean this up gooood.
https://imageshack.us/a/img694/6761/201301240490.jpg
I think next on the list would be to take the exhaust off and cylinder head to check the valves and pistons for damage. With a rough guess, I wouldn't be surprised if the valves are bent and the pistons are cracked maybe?
Soon as the head is removed and inspected, I'll post an update. |
| _Troy_ |
 _Troy_ World Chat Champion
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 19:22 - 25 Jan 2013 Post subject: |
Kinder egss ARE harder to decipher when your an adult - FACT  ____________________ Jogging on, destination living. |
| stevo as b4 |
| blurredman |
 blurredman World Chat Champion
 Posted: 22:18 - 25 Jan 2013 Post subject: |
| stevo as b4 wrote: | It looks like a nice litte Kwak project and very clean in the pic too! Id have something like that any day. Im not keen on belt drive as i'd be more worried about a belt snapping at 80mph, than an engine grenading to pieces. |
Tbh, i'd rather a belt snap on me then a chain.
The belt would also do less, if any damage to the engine nor have the same intensity to locking the back wheel (if at all) if it somehow lodged itself.
A belt snapping, will probably result in nothing more than a gentle glide over to the hard shoulder or side of the road after realising you have no power.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| MillaMeter |
| MillaMeter |
| GrumpyGuts |
 GrumpyGuts World Chat Champion
 Posted: 00:25 - 30 Jan 2013 Post subject: |
Great thread - moar pics  ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012 |
| MillaMeter |
| MillaMeter |
| MillaMeter |
| Xenocide |
 Xenocide Scooby Slapper
| UnspeedySam |
 UnspeedySam World Chat Champion
| Tim.. |
 Tim.. World Chat Champion
| MillaMeter |
| stevo as b4 |
 Posted: 14:31 - 02 Feb 2013 Post subject: |
Nice work on that head so far!
I take it that the pistons and rings were all ok, and so was the existing cam chain?
The other thing is with your nice clear pics, im beginning to see what stinkwheel means about some of the Crap design features of these engines. I Know other Jap engines are very similar in their top end designs and how the camshaft is run in plain bearings in the head etc.
But surely FFS at the design stage in the factory they could have so easily incorportated a large ball bearing into the casting at either end of the cam shaft, and just used the centre plain bearings and end float control thrust section. Also why couldn't they have used a replaceable shell in the centre section bearing, unless you can't accurately combine ball bearing and plain bearings to the tolerances required on the same shaft? I don't see why when everything is new that that would be the case though?
Even replaceable shells on all of the bearing housings would have been as massive improvement over how they let it leave the drawing board. And at least then if oil supply ever does fail to the head then the worst case scenario is a new cam, shells and followers, and the more expensive head casting would be spared and re-usable every time. |
| MillaMeter |
| Xenocide |
| Ed Case |
 Ed Case World Chat Champion
| Ed Case |
| MillaMeter |
 Posted: 14:28 - 11 Feb 2013 Post subject: |
Haven't updated in a while as I was waiting for a cam shaft bung to arrive from Holland Kawasaki.
In the mean time I took the cam chain guide out and didn't look good. Luckily I had a spare in the other engine which was usable.
Comparison:
https://imageshack.us/a/img715/6119/201302030568.jpg
https://imageshack.us/a/img33/5492/201302030569.jpg
Top is the bolloxed 1, note how much rubber has been eaten from the chain and how it's managed to deform it.
Anyway, the bung arrived and fitted, head was torqued up and tappets adjusted. Carbs balanced, fresh oil, oil filter all the usual bollox.
And I gotta say I'm very happy with the results.
See for yourself!
https://www.youtube.com/watch?v=uZ8uWegCHUk |
| blurredman |
 Posted: 14:45 - 11 Feb 2013 Post subject: |
That's an extremely nice looking, and sounding bike!!
I bet you're pleased. You should have given it a bit of a rev on the video though, as nice as it sounded idling.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| mintex |
 mintex Nova Slayer
 Posted: 17:39 - 11 Feb 2013 Post subject: |
Nice one bud, sounds nice and runs well  |
| GrumpyGuts |
The last post was made 13 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
