| hondakawasaki |
 hondakawasaki Nova Slayer
 Posted: 04:28 - 18 Feb 2013 Post subject: cb400 superdream |
hi all
the base gasket needs replacing on my superdream 400 as its leaking oil
i need to take off the whole head and replace all the gaskets
can any one tell me if i need to take the engine out of the frame to remove the head
thanks  |
| bikenut |
 bikenut World Chat Champion
| hondakawasaki |
| smegballs |
 smegballs World Chat Champion
| Casper |
 Casper World Chat Champion
| moonzoomer |
 moonzoomer World Chat Champion
| hondakawasaki |
| bikenut |
| bikenut |
| hondakawasaki |
| bikenut |
| hondakawasaki |
 Posted: 05:36 - 21 Feb 2013 Post subject: |
hi yes the bolts with the seals should be placed in the correct place i dont think they was in my bike
i am still waiting for the new gasket set
i will check balance chain tomorrow its dark now
if it needs adjusting how do i do it?
my manual says its spring loaded so i just unscrew the bolt and re tighten it? is this correct theres no pictures it pretty vague
heres a pic witch bolt do i loosen ?
https://i438.photobucket.com/albums/qq101/daz7189/5-1.jpgthanks i will let you know how i get on  |
| hondakawasaki |
| grahamd1 |
 grahamd1 Trackday Trickster
| hondakawasaki |
 Posted: 05:12 - 22 Feb 2013 Post subject: |
hi, i have now rebuilt the top end took me all day
i now have another problem the bike took about 10 mins to start and when i did get it started there was a horrendous whirry rattly sound coming from under the rocker cover
i did adjust the valve clearances i had to unscrew them for ages to get the feeler gauge under it says 0.10mm for inlet 0.14mm for exhaust
i think i have set them way to big should the valve springs be compressed by the tappets i set them so they have a little play in them a sliding fit with the feeler gauge
please help!!! |
| hondakawasaki |
 Posted: 06:09 - 22 Feb 2013 Post subject: |
also does the engine have to be on the right stroke to set the valve clearances
i remember my cg 125 had to be on the right engine stroke to set the valve clearances
i think i set them wrong now they have a huge gap?  |
| hondakawasaki |
| paddlesat16 |
 paddlesat16 Crazy Courier
 Posted: 15:50 - 23 Feb 2013 Post subject: |
If you own a superdream you need here
https://honda-superdream.proboards.com/index.cgi
lots of like minded people owning superdreams
The piston ring gaps should have been equally spaced at about 120 degrees.
With the head off I would have re-lapped the valves, changed the stem seals and then bolted it back up.
You need to buy a Haynes manual at the very least for this bike especially when your dismantling and rebuilding the engine as you could have bent all the valves by mis-timing the engine.  ____________________ I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T. |
| hondakawasaki |
| paddlesat16 |
| bikenut |
| bikenut |
The last post was made 13 years, 7 days ago. Instead of replying here, would creating a new thread be more useful? |
