Moto Guzzi gear box
martz86
PostPosted: 17:34 - 02 Mar 2013    Post subject: Moto Guzzi gear box Reply with quote
How do, if anyone can help me with this I'd be very grateful.
I'm currently removing the end cover off a gear box from a Moto Guzzi Strada 750. Now I've removed all the bolts and connections but the end cover won't come away from the gear box, bar a few mill, but it seems more stubborn the side which the output shaft is, will the output shaft seal be holding it back and that I need to give it a bit of brute force or could there be something else?
noobRider
PostPosted: 18:18 - 02 Mar 2013    Post subject: Reply with quote
Never had mine apart so I can't help I'm afraid
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
martz86
PostPosted: 18:25 - 02 Mar 2013    Post subject: Reply with quote
Need to replace the gear return spring, so needs must Sad
Guzzirat
PostPosted: 18:32 - 02 Mar 2013    Post subject: Reply with quote
If I remember correctly the gear clusters are mounted to the rear plate so you start dismantling from the front end. First take off the clutch housing then the nut from the input shaft. The cases should then split.
The breather and neutral indicator have to come off too I think
martz86
PostPosted: 20:35 - 02 Mar 2013    Post subject: Reply with quote
So I'll need to remove the gear box, I tryed to do it without removing it, trying to create minimal work but I guess I can't avoid this one. Cheers!
The last post was made 12 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 14 - Page Size: 42.14 Kb
