squeaky back wheel
Meshuggah
PostPosted: 16:27 - 27 Apr 2013    Post subject: squeaky back wheel Reply with quote
Hello everyone. I've recorded a video of what's happening. The back wheel squeaks even if I take the brakes calliper off. Also I've notices it kind of wobbles a lot or maybe it's just my impression. I'm not sure. I had a look at the bolts and they are tight. Have a look at the video if you got 2 minutes. Thanks for your help. https://www.youtube.com/watch?v=ktBD0mMuxEo
Triumph Tiger 800 2012
Ed Case
PostPosted: 16:38 - 27 Apr 2013    Post subject: Reply with quote
At least one of your rear wheel bearings sounds like it's knackered. There's a minimum of two in there and in some instances another one or two in the sprocket carrier. In your case I'd think that there's just the two. If you're any good with spanners replacement isn't too difficult, use common sense (?), take the old ones to a bearing specialist (Yellow pages ?) as they might be cheapest or try Wemoto ?.
Meshuggah
PostPosted: 11:50 - 28 Apr 2013    Post subject: Reply with quote
I don't know when I will have the time to work on it. How safe it is to ride in this condition? I ride to work everyday, It's only 2.6 miles each way. Bloody hell, I took to the garage last week and the guy said everything was fine!! wtf... thanks for your help
Alpha-9
PostPosted: 11:54 - 28 Apr 2013    Post subject: Reply with quote
It'll cost you a lot more in the future if you ignore it, I'd have the back wheel off and be checking everything out and regreasing the spindle and bearings if it were I
Fzr-600 1999
Islander
PostPosted: 12:28 - 28 Apr 2013    Post subject: Reply with quote
Replacing bearings isn't a massive job and doesn't take that long - slightly longer on a rear than a front. The parts aren't that expensive either. If you've got that level of noise and wobble then get them done pronto. Wemoto stock a massive range of wheel bearings and are quick to deliver.
Meshuggah
PostPosted: 23:29 - 28 Apr 2013    Post subject: Reply with quote
Vincent wrote:
All I can hear is the exhaust. Why not try a vid without the engine running? Idea Although there's not a lot else it can be but bearings.
Unfortunately the engine had to be running for the wheel to move fast enough to hear the noise. I'll try to take it to the garage before work tomorrow morning. I'll pass to the guy what you've guys told me. Thanks for your help.
hmmmnz
PostPosted: 08:24 - 29 Apr 2013    Post subject: Reply with quote
your chain looks awfully tight especially with no weight on the bike, are you sure its not chain related?[/quote]
the humans are dead
I kick arse for the lord
YBR Ric
PostPosted: 09:01 - 29 Apr 2013    Post subject: Reply with quote
Running a tight chain will over a period of time cause damage to the rear wheel bearing, and to some extent the gearbox bearing located behind the front sprocket.
Usually the collapse of the smaller rear bearing prevents failure of the larger gearbox one at the same time, but not after causing the damage which will result in its premature failure.
If it is bearing failure causing the noise then replacement of the gearbox one sooner rather than later when damage to the gearbox may also occur would be an extremely good idea.
I've seen ball bearings come out of a gearbox (the result of cage failure) which looked like squashed peas after going down between the shafts, forcing them apart and then cracking both the crankcase halves.
Xenocide
PostPosted: 09:33 - 29 Apr 2013    Post subject: Reply with quote
Your chain is moving about alot - sort of jumping about which would suggest stiff links to me. It could just be the chain squeaking when the stiff bit is bent around the sprocket. Something to check anyway. Smile
KTM LC4 400 | Honda VTR1000
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 14 - Page Size: 65.74 Kb
