| bandit_engineer |
 bandit_engineer Borekit Bruiser
 Posted: 13:56 - 02 Feb 2013 Post subject: SV 1000 Hot starting problems |
Afternoon All,
Does anyone know what can cause "hot" starting problems on an SV 1000.
Bike will start fine from cold, however once up to temperature and stopped. Petrol station etc. will not start again. Will crank until battery is flat however will not fire.
Checked spark plugs. Oil is up to level.
Is there a sensor that could have gone and if so which one?
Thanks
John ____________________ Previous: 2002 Speedfight 50, 2000 RS125, 2002 RS125, 1997 Bandit 600N, 2003 SV1000S
Current: 2007 GSXR 750 (Isle of Man) |
| serlant |
 serlant Brolly Dolly
| bandit_engineer |
 Posted: 20:42 - 29 Apr 2013 Post subject: |
Going on from this.
Valve clearences have been checked and were just below the minimum. This has been sorted and all are now within spec .
However it will still happen on occasions where she will crank and not fire. .
Tried dealer mode and no codes.
Any guidence appreciated
| Ariel Badger |
 Ariel Badger Super Spammer
| bandit_engineer |
| bandit_engineer |
| bandit_engineer |
 Posted: 21:18 - 29 Apr 2013 Post subject: |
yes it will.
it will also start if you crank it long enough to get the FI light to flash and then ignition off and on.
Will have a look at the fuel filter first as this is easier .
Thanks
The last post was made 13 years, 183 days ago. Instead of replying here, would creating a new thread be more useful? |
