Resolved - Motodynamic Brake Light Electrical Problem
Kierran
PostPosted: 09:48 - 24 May 2013    Post subject: Resolved - Motodynamic Brake Light Electrical Problem Reply with quote
Guys just fitted the light tonight. While switched on but engine off the light runs fine but the right one seems to stutter occasionally.
With the engine on its a different story. The brake light flashed for 3 then paused then flashed for three paused and flashed for 3 and so on.
The left was fine again but the right was stuttering intermittently.
Can any one advise?
Im not driving too fast, Im flying too low!
Current Bike - GSXR 750 K5
Current Car - BMW 318i
map
Mr Calendar
PostPosted: 10:33 - 24 May 2013    Post subject: Reply with quote
Is this the American unit?
I ask as flashing brake lights are common in Yankieland. Have been shown to be better as drivers behind are quicker to react to the flash. However, that system is illegal in the UK.
So don't know if you have that system and if it can be switched on/off.
Failing that sounds like it's the usual automotive electrics volts, connector, current issues. I know they do a wiring harness, is this needed to control the LEDs in any way?
Kierran
PostPosted: 10:40 - 24 May 2013    Post subject: Reply with quote
Yeh wiring harness is connected. Also it seems to work fine just running off battery only seems to be an issue when the engine is on. Ill try the connectors again today and see it theres any change
Kierran
PostPosted: 15:15 - 24 May 2013    Post subject: Reply with quote
No idea what was causing it. Mibe the battery was running low and attracting a greater charge but its all sorted now.
https://youtu.be/8ifhE8KThM0
The last post was made 12 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.3 - MySQL Queries: 14 - Page Size: 39.76 Kb
