| Sid_The_Sloth |
 Sid_The_Sloth Trackday Trickster
| MarJay |
 MarJay But it's British!
| Sid_The_Sloth |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 23:38 - 03 Jul 2013 Post subject: |
You'd need sensors on both wheels.
You need to have decent tyres and ride to within the limits of the bike.
It will only do so much, you can't expect to do 60mph on a wet poor road surface and expect it not to lock up when you slam on the brakes hard. If it is locking up then stay back and slow down.
Maybe change bike to something that suits your riding more. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| Sid_The_Sloth |
| Confusion |
 Confusion Scooby Slapper
| Ariel Badger |
 Ariel Badger Super Spammer
| Sid_The_Sloth |
| G |
 G The Voice of Reason
| wots |
 wots World Chat Champion
 Posted: 07:19 - 04 Jul 2013 Post subject: |
| G wrote: | If there is an ABS sensor, it probably is doable, but going to be expensive unless you can get all the kit cheaply - ie, off a crashed bike etc. | Which you might not want to do anyway, as who is to say that the ABS is damaged in an accident.
Also, AFAIK, ABS is not designed to improve braking efficiency as such, more to provide safer braking on slippery surfaces. Not that it always gets that right. Have you braked on snow or wet grass, I can do a far better job than my car can do. The ABS usually goes into meltdown and makes the car incredibly difficult to control. In the wet, it does what it says on the tin.
Usually the ABS system is interwoven with the existing ECU, even though it has a separate control unit and pump usually. For instance, bikes that have ABS, have an ABS light on the clocks, this isn't necessarily just a light wire going live, it could be a signal generated by either or both ECU's working together. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
| MarJay |
| barrkel |
 barrkel World Chat Champion
 Posted: 10:15 - 04 Jul 2013 Post subject: |
| MarJay wrote: | With a cruiser, when you brake instead of forcing the tyre down onto the road in a mostly vertical motion (as would happen on a steep forked sportsbike) it tries to 'push' the tyre along the road. On a sportsbike if you brake too hard the rear wheel will lift. On a cruiser (with the extra weight and length associated with it) when you brake the front end locks up.
Couple this with poorer quality suspension and crap tyres and you're going to find that the brakes are easy to lock. |
With equivalently effective suspension and tyres, a cruiser should, in theory, out-brake a sportsbike. The weight distribution is different and so the front will naturally lock more easily, but the tradeoff is the rear can take much more braking force. Extra weight doesn't matter unless you're reaching the physical limits of the braking system; tyre friction is proportional to weight.
A sportsbike's braking force is usually limited by the point at which it starts going into a stoppie. Above that deceleration force, extra tyre adhesion can't help it slow any faster. Lots of videos around the web showing sports cars outbraking sportsbikes demonstrate this vividly. A weight distribution that takes more deceleration to start rotating around the front wheel can use more of the tyre friction to slow down. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
The last post was made 13 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
