Front wheel puncture (Slime quick Spair)
Screw Loose
PostPosted: 09:55 - 09 Jul 2013    Post subject: Front wheel puncture (Slime quick Spair) Reply with quote
So yesterday i found out i had a puncture, and called the local garage (Sewells in Billingham) who suggested i put some Slime 'quick spair' in my tyre, despite the bottle claiming that it was only a temporary fix and should only be used until somebody can permenantly fix the puncture (which i cant locate, and ive already checked the valve)
The bottle also said not to use it on vehicles with less than 4 tyres.
Despite this i put it in anyway (what other options did i have?)
The garage insist that it will be fine as a permenant solution and will fix any further problems.
Is this true? or do i need to get this stuff out my tyre and replace it with puncturesafe ASAP?
Cheers,
VD
mysterious_rider
PostPosted: 11:53 - 09 Jul 2013    Post subject: Reply with quote
I used that tyreweld stuff it's done okay. Punctures are a pain.
KAWASAKIIIII
PostPosted: 12:30 - 09 Jul 2013    Post subject: Re: Front wheel puncture (Slime quick Spair) Reply with quote
If it's small enough that you can't find the leak, I've seen plenty of people use this as a permanent solution.
Possible you could be risking a blow out, but not heard of that happening.
With some of the enduro tubless systems they suggest using this to help seal it as a matter of course.
Screw Loose
PostPosted: 13:55 - 09 Jul 2013    Post subject: Reply with quote
Cheers guys Thumbs Up Karma
The last post was made 13 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 14 - Page Size: 39.47 Kb
