| Author |
| c_dug |
 c_dug Super Spammer
 Posted: 17:06 - 14 Aug 2013 Post subject: Click from when braking. Not head race or wheel bearings. |
Hi All,
I have an annoying click when braking, I have eliminated the following:
Forks are not bottoming out.
None of the panels are moving.
Brake callipers are not moving (recently did pads so was worth a check)
Head race is fine
Wheel bearings are new
I'm after any suggestions of what it may be, and any ways of eliminating certain things. My friend (the_godfather) suggested it may be my fork bushings, any way of checking this without stripping the forks? I am off on a mini Eurotrip at the beginning of September so ideally I want to get it sorted before them. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Back to top |
| G |
 G The Voice of Reason
| Back to top |
| c_dug |
 c_dug Super Spammer
| Back to top |
| misscrabstick |
 misscrabstick Crazy Courier
| Back to top |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 19:11 - 14 Aug 2013 Post subject: |
My disks move about 1-2mm forward/backward, mechanic said not to worry, they sometimes do, and that I had loads of life left in the actual disc... Anything to be worried about?
I mean its only brakes right
Makes a knocking noise like you're describing. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| Back to top |
| numpty2 |
 numpty2 Trackday Trickster
 Posted: 21:28 - 14 Aug 2013 Post subject: |
It sounds exactly like what I had on my CB250 Nighthawk.
My brake pads are like this, with a hole in one end:
https://www.wemoto.com/bikes/honda/cb_250_m_n_p_r_t_w_x_y_1_two_fifty_mc26/91-03/picture/pads_front_ebc_standard_gg_type/
There is a pin in the brake assembly that goes though these holes and keeps them in place.
In my case, the brake pads had worn a groove in the pin, such that the pads could move around quite a bit. I don't think it was dangerous as such, but it was the cause of the clicking.
I changed the pin, and the clicking has gone, very nearly. I think the holes in the pads had also worn away a little, hence they can still move a bit more than they should. I will change the pads soon.
Bear in mind that brakes are supposed to move a bit anyway. |
| Back to top |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| Back to top |
| G |
| Back to top |
| flumpy7 |
| Back to top |
| c_dug |
 c_dug Super Spammer
 Posted: 22:07 - 14 Aug 2013 Post subject: |
Hi Guys,
Thanks for the suggestions, I'm 90% sure it isn't the brakes, they are a different design with no locating pin, there isn't actually any place for the pads to move front to back and the pads themselves are less than 1000 miles old so they are not moving side to side.
As for the disks, I gave them a tug earlier and didn't notice and particular movement, I will check again tomorrow for front to back and rotational movement, I was really feeling for side to side when I checked.
To be honest I think it's barking up the wrong tree looking at the brakes at all, it feels more like it is the suspension or something between the road and my hands to me. I'm not why I feel like it is the suspension/headrace/handlebars/wheel, maybe I'm getting a feeling through the bars or something when it clicks? Either way I'm not consciously noticing it so it's just a gut feeling. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Back to top |
| cb1rocket |
 cb1rocket World Chat Champion
| Back to top |
| G |
| Back to top |
| c_dug |
 c_dug Super Spammer
| Back to top |
| G |
| Back to top |
| chris-red |
| Back to top |
| barrkel |
 barrkel World Chat Champion
 Posted: 13:41 - 16 Aug 2013 Post subject: |
I've had two sets of steering head bearings changed. Both times the bearings were not fully seated when initially tightened, and got better seated over time, leaving a little bit of click on heavy braking.
One of the mechanics I got to tighten up the head bearings - I was touring, didn't have full tools with me - mentioned that he usually overtightened the bearings when installing them precisely because of this.
Were they replaced recently? ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Back to top |
| c_dug |
 c_dug Super Spammer
| Back to top |
The last post was made 13 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
