 importxs L Plate Warrior
 Kickstart The Oracle
 Posted: 19:24 - 27 Jun 2004 Post subject: |
Holding the front up is not that easy on some bike. If the yokes are OK and do not need removing then a front paddock stand will do the job, probably.
Not sure on the GSXR, but it is quite common on modern bikes to need a very large allen key to remove the front wheel spindle. You should be able to get one of these (if that is what you need) from M&P, Busters or Demon Tweeks.
Once the front wheel is out unbolt the front calipers (although you might have to remove these before taking the wheel out), remove the front mudguard and slacken the pinch bolts on the top and bottom yokes. The forks should then slide out. If they do not slide easily then you can tap the downwards with a rubber mallet (but be careful not to hit them too hard as you will damage the adjusters on the top).
 Frost World Chat Champion
