Replacement Carb for Honda SCV 100 Lead
podmore71
PostPosted: 18:52 - 22 Oct 2013    Post subject: Replacement Carb for Honda SCV 100 Lead Reply with quote
Not sure if this is the right place to post but I'll give it a go.
I am continuely having bogging down issues with my bike, and the only way I seem to fix it is by stripping down the carb and cleaning it, so I'm thinking I need to replace it. I have looked on ebay and there are plenty of carbs for the Honda Lead available from stripped down bikes, but what I was wondering was whether I could fit a different carb to it.
I've attached an image of the original carb and the following is a link on ebay of a carb I would like to know if it would be suitable
https://www.ebay.co.uk/itm/125CC-CARB-YIYING-BENZHOU-MOST-CHINESE-SCOOTER-PARTS-/200407732301?pt=UK_Motorcycle_Parts&hash=item2ea93b504d
Thanks
Andy
cb1rocket
PostPosted: 00:39 - 23 Oct 2013    Post subject: Reply with quote
Looks the same, ask seller for dimensions.
But I would forget fitting a new carb. You obviously have crap in the fuel tank, so why not fit an inline fuel filter then you shouldn't have to keep cleaning it?
podmore71
PostPosted: 10:25 - 23 Oct 2013    Post subject: Reply with quote
I've got an inline filter fitted already, but it's done it twice now since i fitted it. The last time it started to bog out, I cured it by just grabbing hold of the carb and giving it a quick shack, side to side, and then the fuel filter. That cured it straight away luckily, but this time it didn't work Crying or Very sad . Only cleaning out the carb cured it.
PostPosted: 10:26 - 23 Oct 2013    Post subject: Reply with quote
Remove the carb and replace the fuel line, clean the carb.
cb1rocket
PostPosted: 10:39 - 23 Oct 2013    Post subject: Reply with quote
You probably have a sticking float valve
mudcow007
PostPosted: 11:16 - 23 Oct 2013    Post subject: Reply with quote
me thinks you have crap in your tank, carb...or both
can you see any bits in the filter?
if it were me, i would drain the tank, wash it out with water - let it dry
clean the carb
replace filter
replace pipes
ride
moonzoomer
PostPosted: 23:18 - 23 Oct 2013    Post subject: Reply with quote
Other than checking for muck in the fuel also check the auto choke for proper operation, the choke may be on all the time, the choke is located under the small black plastic cover and have been known to give trouble.
The last post was made 12 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.39 Sec - Server Load: 4.42 - MySQL Queries: 14 - Page Size: 51.13 Kb
