carbon/vinyl wrap.
mysterious_rider
PostPosted: 22:18 - 06 Nov 2013    Post subject: carbon/vinyl wrap. Reply with quote
Hi guys, got a bit of damage on the bike and fancy adding a little bit of wrap. I was wondering if any of you have had any personal experience with stuff bought off ebay (it all seems to be different).
The last stuff I got was very average. It stuck but has started to peel away on curves.
Any links/input would be great. Razz
KAWASAKIIIII
CaNsA
PostPosted: 22:20 - 06 Nov 2013    Post subject: Reply with quote
Search works wonders.....
https://www.bikechatforums.com/viewtopic.php?t=250830
https://www.bikechatforums.com/viewtopic.php?t=257490
https://www.bikechatforums.com/viewtopic.php?t=202341
nathan k
PostPosted: 00:03 - 07 Nov 2013    Post subject: Reply with quote
Could experiment with plastidip, they paint whole cars with it.
If it actually works it would be cheaper and easier.
PostPosted: 09:00 - 07 Nov 2013    Post subject: Reply with quote
Titot tried this. It came out shite.
garth
PostPosted: 09:28 - 07 Nov 2013    Post subject: Reply with quote
I'm just about to try plastidip, so I'll update when I've tried or failed.
PostPosted: 11:01 - 07 Nov 2013    Post subject: Reply with quote
You get what you pay for.
Cheap wrap is cheap.
3M Wrap is good.
This tank was done using a single sheet of 3M controltac. You could not do this using the cheapo wrap without piecing it in.
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0760.jpg
That said. Cheap wrap is good to practice with, once you get the hang of it, using the 3M stuff is a delight and you won't make any major cock-ups.
stickybackbob
PostPosted: 16:39 - 07 Nov 2013    Post subject: Reply with quote
Having worked on the technical side of sticky back plastics for 23 years, I'd say I have a fair idea of what works and what doesn't.
The 3M controltac is the dogs doodahs in wrapping.
Cheaper versions all work to an extent but for complex curves, you must use a cast vinyl (very thin and soft) as opposed to a calendered one. Vinyl has a 'memory' and will always try to revert to the first shape it was made in. Calendered vinyl is basically a ball of plastic that has been stretched out but cast vinyl is made in sheet/roll form hence it doesn't shrink back.
The adhesives used only have limited shear strength (to stop the vinyl pinging out around curves) but the controltac has various technologies that allow it to be repositioned before finally set in place.
As with most things, you get what you pay for (and no, I don't work for 3M Smile )
ian505050
PostPosted: 22:01 - 07 Nov 2013    Post subject: Reply with quote
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC06079.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC06084.jpg
https://i267.photobucket.com/albums/ii302/ian505050/ian505050%202/DSC06589.jpg
few bits i did
The last post was made 12 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 14 - Page Size: 61.34 Kb
