| aaronneary |
 aaronneary Two Stroke Sniffer
| base |
 base Trackday Trickster
| aaronneary |
| base |
 Posted: 22:54 - 25 Nov 2013 Post subject: |
you say you made a new rod does it incorporate the ball bearing, that sits onto the pressure plate end,
Here is a link it may be of some help?? there is loads of fzr600 info.
https://www.fzrarchives.com/ipb/index.php?showtopic=56357
its such a simple set up rod, ball bearing short push rod onto pressure plate, if memory servers me correct. |
| base |
 Posted: 23:00 - 25 Nov 2013 Post subject: |
| Vincent |
 Vincent Banned
| 69chris |
 69chris Trackday Trickster
 Posted: 17:20 - 26 Nov 2013 Post subject: |
never having one break myself id be wondering what caused the push rod to break in the 1st place
when you say the clutch failed completely do you mean you had no drive or that the c/lever simply didnt do anything ??  |
| base |
| chris-red |
| 69chris |
 Posted: 18:38 - 26 Nov 2013 Post subject: |
If adjusted up too much they end up turning with the engine and this can apparently cause them to fail, so I have read, on a FZR forum.[/quote]
yep i can sort of agree with that, well, i can agree that might 'burr' the ends of the p/rod,
but that would surely assume that the b/bearing was missing and the clutch was adjusted so tight that it must have been slipping at some point
have had loads of old Z's that have the same set up and never had a problem with pushrods breaking, had the 'worm' lifter fail, had the clutch basket nut come undone and the clutch try to eat its way out through the cover, just never broke the p/rod  |
The last post was made 12 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
