Weird evening
Mario_Kempes
PostPosted: 19:31 - 21 Nov 2013    Post subject: Weird evening Reply with quote
Went to ride my 2005 Hornet home after work and it wouldn't start. The started wasn't making it fire up and it seemed as if petrol wasn't getting to the carb. I checked the line and it wasn't pinched or anything. Neither was the vacuum hose. It seemed weird as it's never given me a minutes trouble and started straight away, as usual, this morning.
So I give up and call the tow truck to take me home with the intention of giving it a going over on saturday.
Couldn't resist messing around and went back out to the garage just now there. Same story again yet when I tried to start it without using the gas it seemed to be trying to fire up yet as soon as I opened the throttle a bit it cut out.
Again with the starter and no gas and it fired up. Was barely idling for about a minute and then steadied and is now back to normal.
Any guesses? It can't have been flooded could it? It wouldn't start from the get go and I always gave it a couple of minutes before trying again.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:44 - 21 Nov 2013    Post subject: Reply with quote
If it has valve shims, I'd say that the valves are sticking open slightly, stopping it from running when cold, but as the engine warms up, the head expands more than the vlaves, opening up the clearances and aloowing it to run properly.
Triumph Sprint ST 1050
Fizzer Thou
PostPosted: 23:01 - 21 Nov 2013    Post subject: Reply with quote
Eh??
If the valve clearances are tight then as the engine warms up the gaps will reduce,not increase.
Perform a compression check first.If there is a low reading,drop some oil down each plug hole.If the reading stays low,the valve clearances should be checked.
Always have a 'Plan B'
Mario_Kempes
PostPosted: 23:03 - 21 Nov 2013    Post subject: Reply with quote
It was parked facing uphill all day. I'm wondering if that has maybe had the float thing in the carbs at a funny angle. It felt like it was starved of fuel.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:04 - 21 Nov 2013    Post subject: Reply with quote
Eh??
The head is made of a different metal to the valves. The head expands more than the valves, making the valves proproprtionally shorter.
It's a 'common' issue on FZs. The first time it happend, it took me about 4 months to work out what the problem was. All the valves were so tight that you couldn't get a feeler guage in there. Once re-shimed with thinner shims, the problem went away...
davebike
PostPosted: 08:34 - 22 Nov 2013    Post subject: Reply with quote
Probably just cold and flooded
But worth a good look over
Air filter and plugs
Plenty oil and not too old or dirty
Check there is coolant in the overflow tank
If all Ok then consider checking Valve clearances yes it has Shims
but not that lightly to be the problem
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
c_dug
PostPosted: 08:44 - 22 Nov 2013    Post subject: Reply with quote
If it was perfect before and is perfect again now then I would go with your gut and assume it was a fuel issue. It is unlikely to be an issue with the shims because those sort of things tend to happen over time rather than suddenly in-between rides and because those sort of things don't suddenly start working again with no sign that anything was ever up.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:14 - 22 Nov 2013    Post subject: Reply with quote
Yes it can happen suddenly. If you have very similar clearences, they'll all get to the point that no clearence becomes minus clearence (at the shim) at approximiately the same time.
As I discovered one morning the day after I'd travelled 170 miles to my fathers...
Anyway... if the problem goes away, fine. It could just be a one off. But generally they aren't one offs.
wilz1234
PostPosted: 18:07 - 22 Nov 2013    Post subject: Reply with quote
Probably just water or dirt in the tank, I too doubt that valve clearances would suddenly be a problem, then suddenly stop being a problem Rolling Eyes
RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650
Nobby the Bastard
Harley Gaydar
PostPosted: 18:39 - 22 Nov 2013    Post subject: Reply with quote
What we need to know from Mario_Kempes is how it behaved today.
Alpha-9
PostPosted: 18:43 - 22 Nov 2013    Post subject: Reply with quote
Eh??
Surely metal expands with heat Shocked
plug chop
Fzr-600 1999
Nobby the Bastard
Harley Gaydar
PostPosted: 18:54 - 22 Nov 2013    Post subject: Reply with quote
Alpha-9 wrote:
Fizzer Thou wrote:
Eh??
I belive that the OP thought that, when I said 'clearence' I meant at the valve/seat interface where-as I meant at the shim end...
I can see how it happened, but when you talk about clearences with valves like this you are talking about the cam( or rocker)/valve interface. You don't talk about clearence with the valve/seat interface, you talk about whether it is seated properly or not...
Alpha-9
PostPosted: 19:03 - 22 Nov 2013    Post subject: Reply with quote
Oh yeah, gaps will reduce, thus making less space
I am spacker brained Razz
sounds like idle fuel mix balancing?
Fzr-600 1999
Nobby the Bastard
Harley Gaydar
PostPosted: 19:12 - 22 Nov 2013    Post subject: Reply with quote
Think in terms of everything working fine when parked, and then not working when he tries to start it a little while later.
Nothing has been touched and once pursuaded to start, the bike runs fine.
It's either one of those transient things that never recur or...
The suggestion that the floats is a good one. The spark plugs being passed theiir sell-by date is a good possibility.
If the problem continues, and the other two are discounted, and the bike runs and starts fine (up to 2-3 hours after last run) but is a fucker to start when cold with a sudden burst into life, I'll go with the shims...
temeluchus
PostPosted: 19:45 - 22 Nov 2013    Post subject: Reply with quote
When were the spark plugs last replaced?
Mario_Kempes
PostPosted: 07:01 - 25 Nov 2013    Post subject: Reply with quote
Well, I've been out and about on it all weekend without it missing a beat.
Didn't trust it enough to take it to work on Friday but went to the garage on saturday morning and it fired up straight away.
It's definitely a bit weird.
I changed the filters, oil and plugs about 6 weeks ago.
Mario_Kempes
PostPosted: 20:07 - 27 Nov 2013    Post subject: Reply with quote
So much for the parked-on-a-slope-float-bowl-stuck-at-angle idea; the bastard did it again this evening!
It started after a good minute holding the started and not touching the gas. Was really rough at first but I just left it and eventually it was fine.
It was cold today but nowhere near UK levels. About 4ยบ at the coldest.
I've never had a single problem with i before this week. New plugs etc.
Can't figure it out.
PostPosted: 20:41 - 27 Nov 2013    Post subject: Reply with quote
Never hurts to give the battery a good charge.
Unless it explodes, then it might hurt quite a bit.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:30 - 27 Nov 2013    Post subject: Reply with quote
I refer you back to my previous answer.
The last post was made 12 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 14 - Page Size: 104.46 Kb
